Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Technical Forums > Engine Machining & Assembly
Reload this Page >
What is the flatness limit of head and deck? Are resurfacing necesary?
Old 10-15-2018, 04:33 PM
Default What is the flatness limit of head and deck? Are resurfacing necesary?
Hello,
I am thinking of taking apart of my junk yard found B20B. I am wondering what is the limit of the head and deck flatness. Are re-surfacing still necessary if they measured good?
Yuta is offline
Old 10-15-2018, 06:38 PM
Intelligently Stupid
TomCat39's Avatar
Default Re: What is the flatness limit of head and deck? Are resurfacing necesary?
How are you proposing to measure your "flatness"?
It's my understanding it's pretty expensive equipment required to measure the smoothness of a surface (RA value) which is the specification I think you are after.
TomCat39 is offline
Old 10-15-2018, 06:41 PM
Yeah... Sorry for the bad terms i used. I am just gonna use a ruler and filler gauge to measure the gap... What is the limit ? one thousandth of an inch? So if it passes, I can skip re-surfacing, correct?
Yuta is offline
Old 10-15-2018, 06:45 PM
TomCat39's Avatar
I don't know off hand what vehicle the B20B is found in, as such I can't see if I have the FSM manual to look up the warp specification.
You actually do want to know if the head/block is flat. And for that you can't just use a ruler, you need a precision straight edge.
I thought you were concerned about the surface smoothness which is important for head gaskets.
TomCat39 is offline
Old 10-15-2018, 07:00 PM
-Intl Steve Krew
Caoboy's Avatar
You’ll need an actual straight edge, not a ruler. You want something that is from Starrett, brown & sharp, etc. a ruler is not accurate enough.
Caoboy is offline
Old 10-15-2018, 07:01 PM
-Intl Steve Krew
Caoboy's Avatar
TomCat39 the b20b is out of a CRV. It SHOULD measure the same as a b18b, but I am not 100% sure.
Caoboy is offline
Old 10-19-2018, 08:04 AM
TomCat39's Avatar
Sorry for the delay. I just remembered about this....
This is from the 97-00 CRV FSM. It only displays one engine so does not identify it but I do assume it's the B20B in question:
TomCat39 is offline
  • Ask a Question
Question Title:
Description:
