Rod bearing question
so I wanna replace a rod bearing in my b18c1. It’s bored to bigger pistons and I believe it’s golden eagle rods and sleeves. I looked on rock auto and they’re are regular and under sized rod bearings. Which ones should I get having different internals? I’m not sure if it changes or what’s in there now if they’re regular or a different size. |
Re: Rod bearing question
1.)Wrong sub-forum.
2.)Nobody here can answer this question for you. You will have to take the engine apart and measure the rod journals and big end bore to figure out what you need. If it's a virgin crank, you will likely need standard bearings but you won't know until you measure. |
Originally Posted by JDM_ego2033
(Post 51627390)
It’s N/A street car the motors built but I’m not gonna build it to a track car or anything. I may boost it down the road but for right now it’s just an all motor quick street car. I guess what I’m trying to say is even if it has after market internals could it still have stock Integra bearings and if not what happens if one bearing is different? I’m assuming it’ll lead to messing up the rod or somethhing |
(Post 51627621)
It’s N/A street car the motors built but I’m not gonna build it to a track car or anything. I may boost it down the road but for right now it’s just an all motor quick street car. I guess what I’m trying to say is even if it has after market internals could it still have stock Integra bearings and if not what happens if one bearing is different? I’m assuming it’ll lead to messing up the rod or somethhing If money isn't a concern, order one set of each; standard, under, over. Clevite standards put me at a perfect .0015 on all rods, BUT, that's also my particular situation. Methinks I just got lucky lol! |
Originally Posted by Txdragon
(Post 51627659)
You can use standard bearings as a start, I am running skunk2 alpha rods and am using clevite standard bearings, for instance. Depending on the condition of your crank journals, you **may** need to mix and match sizes though to hit your desired clearances. For instance, let's say you want .0015 clearance. You **might** need one set to be a standard and oversize. It's a crapshoot at best. You can easily overthink and underthink the situation entirely. One thing to do is order a set of standards and see where you're at when the smoke clears. Install those and check your clearances and see if that worked or if you need to order additional sizes.
(Post 51628179)
if that noise is caused by something or just normal for what my engine has in it |
