Replacing Oil dipstick tube B16a
Got a new dipstick oil tube to replace the old one, nothing wrong just discolored
I glance at the manual and the parts diagram. I don't see any gasket and it appears to be press fit. Any tips or tricks to replace it? Does it just pull out and you push in the new one ? TIA |
Re: Replacing Oil dipstick tube B16a
I normally remove the oil pan and use a socket that fits just inside the diameter of the hole that the dipstick tube is pressed into... and drive the tube out.
Originally Posted by JRCivic1
(Post 51499665)
