Piston to wall tolerance and cross hatch longevity
Getting curious here, how much does running a bigger ptw like say .004 with forged pistons and up cut down on the life of the motor and cross hatch wear. I'm thinking about doing another build but trying to daily it a lot on my 60 mile commute
Re: Piston to wall tolerance and cross hatch longevity
From what i've seen, going too tight is what eats the skirts. Going a little loose you should be OK. I would (I do) just make sure it's warmed up a little more than I would a car with cast pistons before driving.
Ever ponder asking the piston's OEM what his recommended clearances are?
Originally Posted by theYBLEGAL
(Post 52887025)
| All times are GMT -8. The time now is 07:52 PM. |
