Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Engine Machining & Assembly (https://honda-tech.com/forums/engine-machining-assembly-164/)
-   -   piston ring gap question (https://honda-tech.com/forums/engine-machining-assembly-164/piston-ring-gap-question-3259256/)
misfits_skater Sep 19, 2015 05:14 PM
So I was filing my rings, and the second one I guess filed down a little easier than the top one cuz I was shooting for .023 and I ended up at .027-.028....is this ring f@cked now? Or am I ok? and another set came out at both .024, I was shooting for .019 and .023....just wondering if I need to get new rings?
Pro-SeriesFab Sep 19, 2015 06:02 PM
Re: piston ring gap question
What are you trying to do with the motor?
You'll get more blow-by than normal but unless you care about every single HP you can get out of the motor, I wouldn't worry about it.
misfits_skater Sep 19, 2015 06:25 PM
Im going boost....shooting for 400whp. I just dont want my pistons slappin around or have to replace the rings in 5000 miles. Also wondering if I will lose compression or smoke/burn oil in the near future if I run these?
m4xwellmurd3r Sep 19, 2015 10:15 PM
Piston slap is caused by your piston to wall gap and has nothing to do with ring gap.
That being said, I don't know if running that big of ring gap is ok
B and B Sep 19, 2015 10:43 PM
Try measuring the rings in a different cylinder, maybe it's smaller
Could also be bigger,lol
blackeg Sep 20, 2015 03:49 AM
this is the first thing i do if i get a gap bigger than id like. maybe 30% of the time i can get the gap down a tiny bit in a diff cylinder but i think op's gap is too big to make cylinder variation save him.
just gotta go slow and check it often. i also like to try and figure out the pattern of how many turns on the grinding wheel take off a certain amount of ring material and use it as a general guideline.
may need a new ring set but you can likely get them for just one cylinder so not a huge financial loss
turbohatch96y7 Sep 20, 2015 09:27 AM
New ring
Pro-SeriesFab Sep 20, 2015 10:51 AM
I guess it depends on how much another 2nd ring is and if you plan on driving this on the street.
A drag motor which is going to see WOT all the time, again I personally wouldn't worry about it. I've run rings with a larger gap than called for with no adverse effects other than oil dilution by the fuel.
Some high end napier 2nd, may not be worth the extra $80 with shipping . . . basic $20 ring, it wouldn't hurt.
misfits_skater Sep 20, 2015 12:13 PM
thanks for the input everybody, I think I am just gonna be on the safe side and order a new ring set for the one piston that's way off. I was just trying to avoid that, I'm kinda poor now that college started back up lol.
