overheating issues from blown pistons
1 Attachment(s)
hey guys can a blown pistons cause an engine to overheat? is it possible that the block deck and head not be warped but stil overheat because of blown pistons?
Re: overheating issues from blown pistons
Blown pistons can cause overheating because of warping of the head or block service. Additionally that kind of damage, normally also causes a headgasket issue. Which would also cause a heating issue.
Originally Posted by crazes
(Post 51578694)
anyways.. i knew the engine had blown pistons, rough idle tons of white smoke. usually means coolant burning. coolant temperature was rising. And i agree with crazes that usually means a warped head or block or blown headgasket or all of the above. after taking the engine apart i checked the block, head was flat. and the headgasket was not blown. i had the block checked out at a machine shop they said the sleeve everything looks fine.. i just want to know if the blown pistons caused it to over heat or maybe it could be something worse. This question may never get answered here thanks mod.. |
