JE 84mm 9.0-1 pistons in ls? Help pleaze
Sorry for adding another tread with a uncertain question but I've had no luck searching through the threads and I'm hoping to get an answer asap, found a set of used eagle h beams (part number on side of rod 5394-BN) (not sure if actually eagles or not) and je 84mm 9.0-1 pistons for my build (b18b aiming for 500hp) the part number for the pistons is 302410 and everywhere on the internet says they are for a b18b or b20 with a b16 head or a b18c1 , will they work in my ls build? Thanks for any input
