Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Engine Machining & Assembly (https://honda-tech.com/forums/engine-machining-assembly-164/)
-   -   HELP! Question About B18C1 Valve Guides (https://honda-tech.com/forums/engine-machining-assembly-164/help-question-about-b18c1-valve-guides-3348740/)
KilowattBandit May 29, 2020 02:24 PM
delete
TomCat39 May 30, 2020 07:24 AM
re: HELP! Question About B18C1 Valve Guides
Valve guides is not a DIY home job. It's a precision machining process with press fit install.
100 bucks for a valve guide service and complete assemble with new seals is cheap.
You may have just killed that head entirely. Let your machine shop decide if it's salvage capable or not.
1HGEJ2 May 30, 2020 10:34 AM
Re: HELP! Question About B18C1 Valve Guides
supertech sells oversize guides exactly for this damage. but only a machine job
KilowattBandit May 30, 2020 11:08 AM
Do you have a link to these? I typed in "Supertech oversized valve guides" but it shows only oversized valves.
KilowattBandit May 30, 2020 11:12 AM
TomCat39 May 31, 2020 06:51 AM
You are going to have to speak to them and explain the situation. It's not a on the shelf product but I am sure they can make or get some made for you.
