Head gasket size
soo I bought a built b16 off my buddy and I知 redoing the head and need a headgasket. I知 not sure of the bore size and am stuck on what size gasket to get. I was told there are 81mm arias pistons in it. I went to measure the bore size on the old gasket with a caliper but I keeping getting weird number like 75mm and no where even near stock size. Am I measuring right? What should I do. |
Re: Head gasket size
Originally Posted by boostedblue23
(Post 51583184)
Ok soo oem size. Thanks |
(Post 51583312)
Originally Posted by JRCivic1
(Post 51583371)
81mm
OEM Honda, the factory head gasket is good to 82mm bore.
(Post 51583184)
soo I bought a built b16 off my buddy and I知 redoing the head and need a headgasket. I知 not sure of the bore size and am stuck on what size gasket to get. I was told there are 81mm arias pistons in it. I went to measure the bore size on the old gasket with a caliper but I keeping getting weird number like 75mm and no where even near stock size. Am I measuring right? What should I do. I only ask because the D16 has a 75mm bore diameter. |
Originally Posted by DumpdEJ6
(Post 51583953)
This is probably a stupid question considering how difficult it is to confuse the two engines, but you are SURE you have a B16 and not a D16, correct? It is DOHC and not SOHC?
Originally Posted by TheShodan
(Post 51583265)
A stock b16 OEM head asket. This is a no-brainer
I would stick with OEM, if you are going up in size GE is a good choice
