Head gasket size
Old 03-16-2018, 03:44 PM
boostedblue23's Avatar
Default Head gasket size
soo I bought a built b16 off my buddy and I知 redoing the head and need a headgasket. I知 not sure of the bore size and am stuck on what size gasket to get. I was told there are 81mm arias pistons in it. I went to measure the bore size on the old gasket with a caliper but I keeping getting weird number like 75mm and no where even near stock size. Am I measuring right? What should I do.
Old 03-16-2018, 06:23 PM
Moderator
TheShodan's Avatar
Default Re: Head gasket size
A stock b16 OEM head asket. This is a no-brainer
Old 03-16-2018, 07:41 PM
Ok soo oem size. Thanks
Old 03-16-2018, 09:55 PM
JRCivic1's Avatar
81mm
Old 03-17-2018, 03:50 AM
Originally Posted by JRCivic1
81mm
anyone recommend any certain headgasket. Going on a 500whp setup.
Old 03-17-2018, 12:36 PM
civic-steve-94's Avatar
OEM Honda, the factory head gasket is good to 82mm bore.
Old 03-18-2018, 07:21 AM
I like the tuna here
DumpdEJ6's Avatar
This is probably a stupid question considering how difficult it is to confuse the two engines, but you are SURE you have a B16 and not a D16, correct? It is DOHC and not SOHC?
I only ask because the D16 has a 75mm bore diameter.
Old 03-18-2018, 04:57 PM
lmao yeh b16 fully built making around 500whp. I was probably measuring wrong.
Old 11-01-2018, 01:07 PM
DaX
DaX's Avatar
I'm assuming the same holds true for D-series engines as well? OEM gasket is good up to 76mm bore?
Old 11-02-2018, 09:50 AM
jetspeedz's Avatar
I would stick with OEM, if you are going up in size GE is a good choice
slow_ls
08-23-2007 02:12 PM
richeybrooks
09-26-2006 05:58 AM
onlinehost
12-09-2005 02:40 PM
LSVtechnologytur...
12-31-2004 01:23 PM
Fatty_1775
11-29-2002 10:25 AM
Quick Reply: Head gasket size
