H22 thrust washer won't fit
Old 04-24-2017, 09:27 AM
Jianshatch's Avatar
Default H22 thrust washer won't fit
so the thrust washer fits around the crank but the main cap won't fit I fell like I tried everything when I beat on it with a mallet it eats away at the thrust washer I'm getting two new ones can anyone help I've tried to move the crank can u shave them down, is there a small size the standard ? H22a1 with 50 mm mains
Old 04-24-2017, 12:31 PM
Jianshatch's Avatar
Default Re: H22 thrust washer won't fit
Please help
Old 04-25-2017, 06:23 AM
Jianshatch's Avatar
Desperate need of help
Old 04-25-2017, 12:25 PM
PyroProblem's Avatar
Wrong thrust washer??
you shouldn't have to beat anything really...
Old 04-25-2017, 09:37 PM
JRCivic1's Avatar
This shouldn't be... can you post pics of how you have installed the thrust shims and the crankshaft ??? Speaking of the crankshaft... is it a genuine Honda stock H22A crank or something else ???
Old 04-26-2017, 09:51 AM
Jianshatch's Avatar
i was told it was balanced and knife edged ill try washers for the 55 main but the 50 main washers fit around the crank fine but were too thick for the main caps
Old 04-26-2017, 02:36 PM
The thrust washers go in the block on B series. H is different?
Old 04-26-2017, 08:49 PM
JRCivic1's Avatar
This is why I asked the OP for pictures... the thrust shims are placed on either side of the #4 main journal of the block... the #4 main cap should be placed on top to keep them in place when the crankshaft spins.
Old 04-27-2017, 05:47 AM
Jianshatch's Avatar
i have the motor flipped atm due to cams, but I put it on the left side of the fourth main there was a sport on the crank I saw
Old 04-27-2017, 09:29 PM
JRCivic1's Avatar
Your explanation suggests you only used ONE shim... or TWO stacked on one side... I cannot tell. PICTURE PLEASE !!! The shims should be placed, smooth side facing the block (and beveled and slotted side facing the crankshaft counterweights), on either side of the #4 main journal of the BLOCK. You will see two smooth machined surfaces on the #8 and #9 counterweight of the crankshaft... each facing the #4 main bearing journal.
This picture places the parts in an invisible block sitting right side up as it would be installed in your car. Part #3 is the thrust shims (although they are in fact pictured backwards as installed).
CRANKSHAFT - PISTON for 1993 Honda PRELUDE COUPE
Old 04-28-2017, 05:12 AM
Jianshatch's Avatar
in the picture I see then both comes down I put so on the left side but had one on the bottom and one on top where it looks like a circle
Old 04-28-2017, 07:19 AM
Raf99's Avatar
sounds like the wrong part, compare to the old ones to check
Old 04-28-2017, 07:39 AM
Jianshatch's Avatar
I did I got a spare h22 block I'm gonna open up and see how it's placed
Old 04-28-2017, 01:10 PM
Jianshatch's Avatar
figured it out lol I had both washed together on one side like bottom and top didn't know they went on both sides
Old 05-12-2017, 09:39 PM
motoxxxman's Avatar
as soon as you said mallet and main cap, I knew this was the case. glad you figured it out. hope you didn't destroy the main cap, block, or crank in the process
hondahoff
04-19-2011 09:41 PM
uhhhhhhhhhhhhhhhson
07-28-2006 11:01 PM
deoexmacchina
04-18-2006 08:38 PM
hu
01-29-2006 11:24 PM
Root79
01-30-2005 01:50 AM
Quick Reply: H22 thrust washer won't fit
