Gsr Block with B18B crank timing.
Old 04-29-2019, 04:31 PM
Default Gsr Block with B18B crank timing.
Hello guys, I'm sure this subject has been covered numerous times. I've done alot of research and tried every possible recommended method for the past 3 days. I'm installing a new timing belt, put the belt on with all the marks perfectly lined up. I tighten the tensioner and the crank gear moves counter clockwise a little. No matter how far off I set it or if I leave it exactly at TDC. It never falls exactly at the mark. Only a few degrees off. Now I'm not sure if the head I have has been resurfaced. The head was on my gsr block which had a gsr crank. This new css block has an LS crank. Could the timing mark's be off because of the crank. I used an extension in the #1 cylinder to verify tdc and the camshaft marks always line up correctly. The problem is the crank gear moving counter clockwise each time I tighten the tensioner. I attached pictures. Any input will help. Thanks.
Excusetobooost is offline
Old 04-29-2019, 05:00 PM
Default Re: Gsr Block with B18B crank timing.
Just wanted to add that the water pump, belt and tensioner are all brand new B18C1 parts.
Old 04-29-2019, 09:12 PM
Your issue is that your block was decked by CSS when that process was done and thus, your crank TDC mark will be slightly retarded... and from the looks of your photos, it appears just about perfect (assuming that the cam gear timing marks are in fact pointing toward each other in the window of your cam gear fixture - I cannot see the marks in your first pic).
JRCivic1 is offline
Old 04-30-2019, 02:29 AM
Wow yes very true. Thank you soo much I've spent a lot of time trying to figure this out. Yes the cam gear Mark's are pointing towards each other. Now I can move on and get this project together.
  • Ask a Question
Question Title:
Description:
