F22B2 Cracked Deck Between Sleeve
Title says it all. My block has a crack between the middle sleeves right in the middle. Would it be safe to use a MLS headgasket or is the block trash? The sleeves are still good. I plan to boost the engine. Im not too experienced with rebuilds. This is my first sleeved open deck engine.
https://cimg6.ibsrv.net/gimg/honda-t...494bb9f24c.jpg |
Re: F22B2 Cracked Deck Between Sleeve
It might work for a short while if you leave it stock... it likely won't survive the dyno tuning session if left as is. Replace the block and then boost it.
Yeah I was afraid of that, I checked and my mls headgasket has ridges that seal on the sleeves. I saw on some diesel tractor forums that people have gotten away with similar cracked blocks on their older tractors. But of course it's different. Im not sure where to get a cheap block, I already got custom forged pistons. There's a block at the junkyard for about 150 but the car has bad motor spray painted on it. And it's got 200k miles
| All times are GMT -8. The time now is 01:38 PM. |
