From D series to B series Vtec
Hey everyone! I’m planning on a complete B series vtec swap for my 93 EG coupe . Which is currently a SOHC d16z6 vtec. Not familiar with the complete swap but my buddy has given me a free B16 head, so I was thinking of doing the swap starting with this free head I got . Since I am a noob to this B series swap, can you guys help out with the complete part list i’ll need for this project? Also, I don’t FOR SURE need to use the head I was given if that isn’t the best route for this swap. I don’t mind finding the correct head for the long block I’ll need . So far I’m thinking ill need : B16/B18 head , B16/B18 long block (with internals) , distributor, shift linkage , LS or GSR tranny , integra axles, ECU (from a vtec model) , intake manifold, exhaust manifold. This is all I’m aware of now . Any of parts that you guys know of or any advice would be awesome! |
Re: From D series to B series Vtec
There’s a sticky for this in the hybrid swaps, has all the info regards to swaps. |
DO NOT get an LS transmission if you intend on enjoying the car's power/performance. Gears are way too long for 90% of applications.
Look into how to build a B20VTEC engine. If you're going to be re using the B16 head, this is a good opportunity to get a cheap B20 block and put the B16 head on it along with an LSVTEC kit. Use a B16 transmission if you want to enjoy the performance. GSR is too long (imo) but would still not be as bad as an LS trans. Edit: Just realized this topic is 2 months old and OP is long gone. |
Originally Posted by Chance EG
(Post 51881551)
Look into how to build a B20VTEC engine. If you're going to be re using the B16 head, this is a good opportunity to get a cheap B20 block and put the B16 head on it along with an LSVTEC kit. Use a B16 transmission if you want to enjoy the performance. GSR is too long (imo) but would still not be as bad as an LS trans. Edit: Just realized this topic is 2 months old and OP is long gone. Hey , I now have a complete b16a1 vtec long block . I found an LS tranny that I was interested in buying . Would this still be a bad combo ? |
Originally Posted by Anthony Lorenz
(Post 51881600)
Hey , I now have a complete b16a1 vtec long block . I found an LS tranny that I was interested in buying . Would this still be a bad combo ? Get a B16 transmission. |
(Post 51881789)
Yes, terrible. Especially with the B16's low torque as a 1.6L
(Post 51881551)
If you swapped in a b16 or gsr tranny you would probably be very surprised how much better the car feels over all. Hydro ls trans are really only good for a higher hp turbo ls or b20 in my opinion. I drove a b16 with a ls trans that didn't have vtec working and I could have sworn it was a single cam lol. |
Cable ls trans is a different story though. I rather enjoy cable ls trannies |
Originally Posted by K7-1Ktrevor
(Post 51883365)
(Post 51883366)
Cable ls trans is a different story though. I rather enjoy cable ls trannies Yeah I am one of the few rockin the '86-'89 (I believe) small spline cable LS trannies. Other than it showing its age, I have no problem with it. Although it is true I haven't driven on a b16 or gsr trans to see the difference. But what would be the difference between LS hydro and LS cable? Same gear ratios I would presume? |
Originally Posted by 2x0
(Post 51883662)
You can compare a 1st -> 2nd gear shift with almost any OEM transmission and the shift point will be similar, the differences start adding up in 2nd, 3rd, or 4th gear as the final drive and ratios start to have more of an impact on the speed per RPM/gear. I've driven B16's with LS, and B20 (non VTEC) with LS on all motor cars. IMO, it's a terrible way to kneecap what would otherwise be a rev happy/responsive NA motor. I wouldn't even recommend an LS tranny to most people running a turbo unless they were pushing bigger power or had a specific purpose in mind. The LS trans has it's place, but a lot of people aren't fans after sharing similar experiences as above. |
(Post 51883662)
Oh?
Yeah I am one of the few rockin the '86-'89 (I believe) small spline cable LS trannies... |
Originally Posted by JRCivic1
(Post 51883973)
I think you meant a '90-91 small spline LS tranny... the '86-89 won't bolt up to a "B" series engine. The '86-89 has the same bellhousing design as a "D" series does.
