Confirm if this is the thermostat bypass hose - Honda-Tech - Honda Forum Discussion
Old 07-10-2018, 07:42 PM
Curlybandit's Avatar
Default Confirm if this is the thermostat bypass hose
Hey everyone.
I have a '93 del Sol Si with a JDM GSR swap. I noticed a subtle smell of coolant in the cab when driving. When I looked under the hood I saw a tiny spray of coolant coming from pin-hole in the small hose that attaches from the thermostat housing to the passenger side of the intake manifold (using a Skunk2 GSR IM) where it mounts to the head. I believe that it's called the thermostat bypass hose.
Can anyone confirm this? I've attached a picture.
Thanks!
Curlybandit is offline
Old 07-12-2018, 09:43 PM
Default Re: Confirm if this is the thermostat bypass hose
The bypass hose is the larger 5/8" L shaped hose in your photo. The smaller 5/16" coolant hose is part of the T/B and IACV de-icing circuit. This small port on the Skunk2 I/M just below the bypass fitting can be un-necessary in some applications, so you will have to examine what you have and how the circuit is run.
JRCivic1 is offline
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
Description:
