Cam grind
Can the B18b3 non vtec cams be ground to the vtec power profile.Going in a mini jet boat where nothing under 3 grand
Re: Cam grind
You would have to contact Web Cams to check that, but you can buy Crower 62403's (Stage 2) cams and they have very similar lift/duration to GSR cams. They sell for about $380... I am not sure you can get a set of cams cut/reground for less than this.
Good luck. |
