B20v all motor rebuild ?
I have a b20b high compression my head gasket went and piston ring number 2 piston compression was 180 ok number 2 and 210 on the other I take the whole motor apart so I have a few ? If anyone know and can help me I seen a few mark on number 2 piston wall on the block so i was doing to rehone it to 84:5 and get type r piston I seen with arp rod bolts and acl bearing do I need anyrning eles I need I should ifs my daily car just like to have some fun and some pulls but Notninf to crazy my step up will be b20b with type r piston 84:5 with stock crank with a gsr head with super tech spring and retailers and I got gsr cams was thinking type r cam but not sure if I should does any know and what eles should I do to be a safe build fully block apart and head I got a rebuild b16 Tran to go With it wns new water pump and timing belt and water pump and etc trying to be on a budget to but better be save them sorry and do it once lol so my ? Was it’s the piston plug and plug with stock b20 rods or do I need to do anything eles to make it work and if I want to put super tech spring and retailers do need to take it to machine shop to shave the head inside or I can do it my self
Re: B20v all motor rebuild ?
itmight helpifyou can actuallybreakup yoursentencingand addsomepunctuationssoit'snotso hard toreaditandstuff.
paragraph |
| All times are GMT -8. The time now is 03:48 PM. |
