B18c1 rebuild help fo a honda noob
Old 07-16-2018, 03:04 PM
Default B18c1 rebuild help fo a honda noob
Hey guys, trying to help my buddy with his turbo b18c1 setup. I gave him the turbo and engine i picked up from a friend a few years back. Got it in the car, ran at idle but needed tuned badly. Tuner did compression check and leakdown and said it failed leakdown test. So we have pulled the head and im having some questions since i didnt buold this motor im trying to figure out whats in it to order new parts.
heres what i know:
block has been sleeved and bore measures 83.5. Headgasket measures 83.85 and is mls felpro or oem not sure. Has ARP head studs. Aftermarket cams, cam girdle. Prescision 76mm turbo, biggest damn header and down pipe ive ever seen on a honda lol. Big intake manifold and AEM rail 500cc injectors and Walbro 255 pump. Guy i got engine from had dyno sheet when it was in his EG hatch 418 whp.... engine sat in my garage 4 yrs.
unknowns: im not sure the stroke, what rods are in it, or what crank all i was told was forged everything
i noticed after pulling the heads that the piston seems to be looser in the bore than im used to (domestic ls and sbc stuff) i can move it around maybe .30 by hand...
SO FINALLY THE QUESTIONS lol:
1. Does anyone know what an aftermarket 83.5mm piston actually measures with proper clearance?
2. What headgasket measurements should i be looking for to order new ones?
3. Copper, mls, or what...cometic? (prob 15 psi with 76mm precision turbo)
4.What ring gap are the boosted guys running?
5. Side question, anyone know why a ecu with hondata is so damned expensive? Dude is quoting 1500 to tune the damn thing lol
im a bit out of my wheel house here on honda stuff... i gave this engine to my buddy for free since he blew his, now i feel bad since we are having issues... so any help would be appreciated thanks
Renegade1 is offline
Old 07-17-2018, 01:24 PM
1HGEJ2's Avatar
Default Re: B18c1 rebuild help fo a honda noob
1. no piston in 83.5mm wiseco..cp..or supertech..use 84mm 10:1 pistons
2. oem headgasket bored to ur size (golden eagle)
3. No copper need
4. 1. 0.45-0.50mm 2. 0.50-0.55
5. hondata s300 isnt expensive tune price is 300-700$
1HGEJ2 is offline
Solster
Engine Management and Tuning
04-15-2011 02:08 AM
1990CRXSIJDMEF8
08-17-2010 10:54 PM
LSteg460
01-19-2007 02:59 PM
mikeunreal2
12-27-2006 04:50 AM
Bambooseven
10-20-2004 07:48 AM
Quick Reply: B18c1 rebuild help fo a honda noob
  • Ask a Question
Question Title:
Description:
