Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Engine Machining & Assembly (https://honda-tech.com/forums/engine-machining-assembly-164/)
-   -   B16a2 head (https://honda-tech.com/forums/engine-machining-assembly-164/b16a2-head-3381522/)
jhosua89 May 28, 2025 10:50 AM
B16a2 head
Found a B16A2 Head with
Supertech 85# springs and retainers
Skunk2 Tuner Stage 2 Cams
New Supertech Valve Seals
Supertech LMA Springs for $1500 would this be a good head to put on my low comp b20b
JRCivic1 May 28, 2025 08:11 PM
Re: B16a2 head
Better than the head that was on your low comp B20B engine... it would really be good if you put some rods and higher compression pistons in that B20B instead of running it stock. ;)
jhosua89 May 29, 2025 05:19 AM
Re: B16a2 head
@JRCivic1 what pistons do u recommend
JRCivic1 May 29, 2025 08:18 PM
Re: B16a2 head
There are lots of good choices... the right choice will depend on many factors. Intended use, fuel used, and connecting rod choice are just a few.
