Any builders to comment on Valve head size vs Stem diameter?
I'm messing my with old 12 valve iron block and bumping up the valve size. Stock exhaust is 35mm with 7mm stems. Is there any reason to worry about 36/3mm heads with a relatively skinny 5.5mm stem?
Could the heavier head and stronger valves springs be any factor on a thinner stem? |
