1995 Integra GSR OEM piston ring gap problem
Hi all,
So last year I spun a rod bearing, and had rod knock. I examined the crankshaft, and it was within spec and without scoring. Though the rod journals had excessive scoring. I found non molested pistons and rods online, and bought a whole new bearing set. I also bought new rings from rockauto. Though when i got them, i noticed the gap was excessive. When installed, the piston has a lot of lateral play within the cylinder wall. So I instead bought OEM acura rings from the dealer. But the Acura rings still have a huge gap. The gap is supposed to be 0.0014mm. The gap is about 0.8mm. I Mic'ed my cylinder wall and it is within spec. The old pistons that were inside the blown engine seem larger, and show it on a mic. However, the original pistons that I took out of the blown engine have no play, and are the right gap. same thing with the rings that were on the pistons I bought online. Can anybody tell me whats going on? Im about to just throw the old rings in the damn thing and send it, though that wouldnt be ideal. Money is a problem, or else Id just buy an unmolested b18c1. I attached photos to explain the situation betterhttps://cimg9.ibsrv.net/gimg/honda-t...5ab3f24e33.jpg https://cimg4.ibsrv.net/gimg/honda-t...67acc5345a.jpg https://cimg1.ibsrv.net/gimg/honda-t...ef9e5248d2.jpg https://cimg6.ibsrv.net/gimg/honda-t...71f3af7809.jpg https://cimg9.ibsrv.net/gimg/honda-t...406d448002.jpg |
Re: 1995 Integra GSR OEM piston ring gap problem
different pistons
Those cylinder walls look scratched up. Might want to take care of that before going further with the rebuild |
What ended up happening did you find the right rings |
