Who is running a twin disk with a cable tranny?
Im starting a new drag project, this time with a CRX. To keep things simple Id like to stay with the cable trans. Recently though, Ive heard a few reports of people hating the cable set ups when running a twin disk type clutch.
I have in my posession a YS1 (USDM 92-93 LS) transmission and a Hydro B16 gear set which I plan to swap into the YS1 casing with the addition of a ATS 1st gear and a JDM Honda 4.785 FD.
Im just looking to get some feedback from those who are using cable transmissions. Are there really any downsides?
This will be for a NA drag set up.
Thanks
Thanks
Re: Who is running a twin disk with a cable tranny? (Innovation)
i am running a ys1 w/ exedy twin disk i will let you know how it feals my car should be done in 2 weeks
Re: Who is running a twin disk with a cable tranny? (b18bturbo)
we ran a cable (ys1) trans last year on the Pro4 car. The only prob that we had was the cases and 4 gear breaking under very high loads. If you are running NA you probably will not have any problems with it. look into getting the phantom grip trans girdle it will help with the loads on the bearings and keep the gears in mesh at all times.
Good luck
Duck
Good luck
Duck
Re: Who is running a twin disk with a cable tranny? (N2O)
The usual problem is you dont get enough throw with the cable to make a twin disc work properly. I run the RPS twin carbon with a cable trans and it works just fine. There first model had issues with the release, but we worked together on it and now their new design works awesome! You can even use the stock t.o. bearing. If you do have problems though, you just have to cut a lil notch on the arm comming out of the trans. It will change the ration and make the pedal more heavy, but will give you more throw and once again you wont have problems...
Re: Who is running a twin disk with a cable tranny? (SpeedDreamz.com)
i ran the comp. clutch in an s1 cable trans and im switching to a ys1 this season and once i setup the pedal stop, i never had an issue.
1 Post
Used the ClutchMasters in our racecar with YS1 cable and 25" slicks ... although only allmotor, it took a lot of abuse and lasted two seasons of sheer abuse. No problems shifting either, even at 11K+ RPMs in some instances.
I do send the clutch back to CM for inspection after each season, but usually all is well despite the abuse we put on it.
Greg
Greg
Re: Who is running a twin disk with a cable tranny? (CHEETAH)
Im considering the competition clutch twin disk.
Im starting to get a little less worried aabout sticking with the cable trans
1 Post
I ran an exedy twin disk with my YS1 transmission with no problems at all. The season before I ran a clutchmasters twin disk the season before with a j1 trans (small shaft cable) no issues either. I personally feel that the exedy clutch is a better made piece, no modifications needed at all, and utilizes a stock Throwout bearing.
Re: Who is running a twin disk with a cable tranny? (XXXRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XXXRacing »</TD></TR><TR><TD CLASS="quote"> I personally feel that the exedy clutch is a better made piece, no modifications needed at all, and utilizes a stock Throwout bearing. </TD></TR></TABLE>
Good info to know right there. Thanks Brian
Phil
Phil
Hello im using b16 tranny cable, but cant do shifts when the motor is on, im using competition clutch, plz need help, if any1 have pics what can i do !!!!
ramco
Transmission & Drivetrain
11-06-2009 10:42 PM
