What is the "Offical" fastest Nitrous honda record? B/K/H?
#52
1 Post
Re: What is the "Offical" fastest Nitrous honda record? B/K/H?
awesome results. looking forward to seeing it full all out.BTW nice wheels
DDTECH, thanks for your advice on my nitrous setup. Looks like I leaned it out a little to much(bunch of problems with setup including fuel issues) but still managed a 11.70 on it. Rings on number one took a crap but car still runs fine. Gonna build a motor and go at it again.
#53
Depending on Fuel, will depend on AFR. We spent the better part of 8 hours on the dyno last weekend testing FTW fuel, and finally dialing in everything.. and got everything ironed out, i had a very poor showing at ifo with a bunch of fueling issues that i had to figure out.
Spark plug reading is important, very important for a nitrous motor. If you're on pump gas shoot for 11.5-11.8 AFR on the gas, and i normally pull more out then normal, Dont run too rich, its actually alittle more dangerous then running lean. Thank of your spark plug like a fuse.
If you have any questions or need any help, contact me.
#54
1 Post
Sorry to hear about your mishap.
#55
I went 10:70 in 2010. With a B. Since then I have not run my car. Will be back out this year. The car will go 9s. Learned the hard way on a lot of things and cost a lot of money. But now I know.
#56
#57
I drive a nitrous car, its not the fastest but i think it has a lot of potencial down the road. Setup:
Stock block b20(from oilpan to headgasket)
Skunk 3 tunner 2
Skunk 2 valvetrain
Tri y rep header
Skunk 2 ultra street Im 70mm tb
85 wet shot tuned on c85
11.03 @ 120
Skunk 3 tunner 2
Skunk 2 valvetrain
Tri y rep header
11.03 @ 120
#60
Skunk 3 tunner 2
Skunk 2 valvetrain
Tri y rep header
85 dry shot tuned on c85
11.03 @ 120
Skunk 3 tunner 2
Skunk 2 valvetrain
Tri y rep header
11.03 @ 120
#64
1 Post
Skunk 3 tunner 2
Skunk 2 valvetrain
Tri y rep header
11.03 @ 120
Skunk 3 tunner 2
Skunk 2 valvetrain
Tri y rep header
11.03 @ 120
#65
#66
1 Post
Im assuming this would be the high comp b20 bottom end? If that's the case, how did you get the pistons to clear the valves using the tuner 2 cams?
#67
#68
I would like to update this thread.
I finally was able to figure out all of my fueling problems after my embarrassing showing at IFO about a month ago...
I was also able to do alot of testing with the FTW Clear vs Q/C16 and C85. Anyway
Ended up making a good bit of power on motor, but Nitrous is all i cared about. Direct port 100 setup, i ended up making 38xwhp with a nitrous leak at the block. Fix it, and went back just to see, i ended up making 420whp on just a 100shot on FTW Clear Fuel.
Stock sleeve 85x89 B20VTEC. I'll be going back to the track hopefully in a few weeks. Just bought a new house and been really busy..
#69
That thing should boogie DDTECH. We know what 400+ whp does with the all motor cars at 2150 or whatever they weigh. I know it is a little different, but that thing should be a solid mid/low 10 car if not better after you get some practice with it and get it all sorted out.
#71
There are at least 5 sub 10.50 Kseries setups that I know of, hell on 1 went on 10.48@132 on stock motor, 225~ ish DP on C16. I went 11.62@123mph with a simple 100 shot on a k20a2 that made 215whp on motor in 2011. Been thinking of putting the car back together with a big DP kit.
With a dedicated fuel setup/fuel cell and race gas there is no reason one can't go 9s. I was thinking about going for 9s, with a 260-270whp K20 or K24/k20+ a 200ish shot with dedicated fuel pump/cell with c16 but then sort of gave up when no one could give me a solid answer on what custom pistons+ strong enough rods to run for the big shot/somewhat while still being somewhat streetable at 270whp~ on motor.
With the price of what it takes too put together a fast nitrous setup you'd think there would be plenty in the 9s, someone needs too allow them in a class like said above.
#72
#73
I think Kurt Gordon from kg he had a nitrous street car back in the day he might hold a record
#74
I don't know if he ever held any records or anything, but I did buy my first nitrous kit from him. Back in like 1999-2000 I ordered a dry kit from him and put it on a D16Y8. Ran a 60 dry shot through it, then sold the kit later to a friend that had the same car and engine except his was an automatic. We used to sneak people with that one.
#75
There has been a lot of time to bring in some ET reports DD.
Where is your progress report? I am waiting to see your results.
