Vanjen clamps info
Vanjen clamps info
Looking at using these clamps for my new setup. But wanna know if these would be my best choice. Are there any other clamping systems like this that are cheaper or same price that are better?
Just trying to find info on the best clamps to use.
Re: Vanjen clamps info
The pegasus clamps look like they would be a stronger version over the vangen. They don't have the name cutout causing a weak point like the vangen's do.
Ihave used both. The Pegagus are harder to get lined up and clamped and also leak at some angles. I'll be cutting off the Pegagus and replacing it with a Vanjen..
How are both with engine movement? I will have solid mounts. The last setup with the mounts didn't move more then a 1/8 of an inch. Only know this cause the turbo was right against the headlight support and it was able to just barely nick it.
I had to replace the ferrules (because they cracked) and wrap the Wiggens with a worn clamp so that it didnt blow apart.
nothing like a .50 cent clamp to hold the $200 one together. The van jens work i have had a few break on me but something you shouldnt be inspecting every now and then.
