S300 Launch Control settings for Drag Racing
I have a fully built GSR turbo setup, with a Top mount full race manifold with a t4/s366.
I'm trying to mess with the Launch Control Settings on the Hondata S300 and build at least 10 psi of boost off the line, I would like to see what numbers you guys are using in the Fuel & Ignition Settings. Activation RPM??? Fuel Enrichment???? Ignition Retard??? I know every car is different but if I know where to start at that would help a bunch. |
Re: S300 Launch Control settings for Drag Racing
I think more information is needed. Engine displacement, compression and etc.
Oh ok , here you go
84mm b18c1 golden eagle sleeves, 9:1 compression, gsr head with skunk Pro 1 cams, twin disc, JG intake manifold, bosch 1000cc injectors on e85 It made 600hp/400tq on a t3/T66 turbonetics turbo, about to go to the dyno to see what the new manifold and turbo will make. |
try like -20 timing and 20 fuel
they like to be richened up and timing pulled out(as far as mine goes) i can build tons of boost sitting there if i wanted to. activate it about 300-400 rpms before the limit that you set. |
mine I have 90 fuel enrichment and -20 on the timing
wow it seemed to work out... set the activation at 7200rpm and the launch control at 7500 and with the 90 fuel enrichment and -20 on the timing.. it went to around 10-12 psi..
that will work! thanks |
Activation RPM 7400
Launch Control 7600 Fuel Enrichment 400 Ignition Retard -35 VTEC SPEED 0 MPH |
fuel enrichment 400??? or 40?
400 seems kinda high lol.
400
mine were kinda high as well, but when boost finally did come on it sounded like an f15 starting up
i think mine were like 150 and -20 |
How much boost were you building? What do most people leave the line at?
fuel 15
timing -10 launching at 6700rpms. 1.63 sixty foot (real street car)...i dont really launch with any boost...dont need to. |
awesome! i've been wanting to do this with mine, just haven't really had a chance yet...
400 fuel holysh*t, I had no idea you could do that.
Originally Posted by dustin528
(Post 39967281)
Originally Posted by sgnlab
(Post 39966486)
400
Originally Posted by mrbsponge
(Post 39966648)
Mine is setup for a 7000rpm rev limiter untill 10mph. with no added timing. There is no reason for me to build any type of extra boost. I have a serious traction problem as it is. At least at the import face off I spun untill 3rd (smoke pouring off the tires) then when I would finally hook I pressed the button and hit high boost.
Originally Posted by fmfkid250
(Post 39970932)
Your setup is almost like my setup, same turbo, gas, and power. Nice numbers by the way. I'm trying to hit 10's with this turbo. What size a/r is your exhaust housing on your s366?? |
good luck tuan!
thanks jeff.. only out there for fun.. and hopefully some 10's...
Originally Posted by ek_b20_vtec
(Post 39970184)
really.. how much boost are you building off the line??
And about 25 pounds outta the hole :) |
Originally Posted by dester223
(Post 39976108)
On my 372 setup, it was about 400-500 fuel enrichment also.
(Post 39970977)
What size slicks are you running???
Your setup is almost like my setup, same turbo, gas, and power. Nice numbers by the way. I'm trying to hit 10's with this turbo. What size a/r is your exhaust housing on your s366?? Thanks goodluck your going to have traction problems Do you mean 9's??? 10's with that power isent going to be a problem. One pass I spun 1-2 then I hooked in 3rd untill the 1/8 let off it still went 10.8@114. |
