roll cage question? back seats?
#76
Re: roll cage question? back seats?
you will need the rocker panel bar that the d bars connect to. i didn't have them the first time i went to see him and i had to go back. this bar is to keep the car from caving inwards. you need it because it will be safer
#77
If you are going to buy a kit, kenskustomchassis is the best. it comes pre-notched, but you will still have to fit it.
#78
Ah cool yes I could do that. PM a time when your there. I'm right around the corner. I know what will pass tech in this area.
#79
#80
is there any work around for a retro fit, like c notching the rocker bar into the existing d bars? my d bars go to a 6 x12 plate in the center.
#81
#82
is the bar sitting on the center console? What keeps the center of the bar from caving? what did you use to notch a bar already welded and in the car??
#83
I have one more question about this
Is this legal for drag racing? I know NRG tech did it but is it legal to bend the plate around the tunnel like this? this would be much easyer than the other ways i have been told to do it. Cause my rockers dont have much room to work with
I have this to work with.
Thanks guys
Thanks guys
#84
the other option for you is to run the bar across like turbotyper@spec posted that the d-bars are supposed to go to, then you won't have to worry about were the 6x6 plates go.
i just got the 2010 nhra rule book and it does state that there needs to be a bar going across from sill to sill to run the d-bars to.
#85
It was a pain in the ***!
#86
Thanks guys
Thanks guys
#89
Steve Lecours @ 1-905-665-8006.
above is the contact info for the nhra inspector for our area (toronto)
below is contact for our division tech director
Ryck Campbell rcampbell@nhra.com
#91
Edited as the inspector and i apparently were not on the same page..... i have another call in to him. i think maybe i just need to schedule him to look at it in person.
but adding this bar would not be easy by any means in my instance.
#92
looks like my Audi driving *** is here by myself now, but FWIW here is the wording for this:
Originally Posted by interwebz
"D" bar installation for full-bodied cars:
For front-wheel-drive cars, with complete OEM floor (from the firewall to the rear of the trunk) and rocker/sill boxes, the 1 1/4-inch x .058-inch CM (.118-inch MS) "D" bars (when required; i.e., when the main hoop is not welded to the frame) may be welded to a 1 5/8-inch x .083-inch CM (.118-inch MS) crossmember welded to the rocker/sill box via conventional 6-inch x 6-inch x 1/8-inch-thick plates. For rear-wheel-drive cars, with neither a frame nor subframe connectors, but with complete OEM floor (from the firewall to the rear of the trunk; exception: the rear inner wheelwells may be tubbed with steel or aluminum) and rocker/sill boxes, the 1 1/4-inch x .058-inch CM (.118-inch MS) "D" bars may be welded to conventional 6-inch x 6-inch x 1/8-inch plates attached to the driveshaft tunnel.
Roll Cage:
Open-bodied cars running 9.99 and quicker and/or faster than 135 mph must meet applicable SFI Specification for e.t. (see Class Requirements). Full-bodied cars running 8.49 and quicker and/or exceeding 180 mph must meet applicable SFI Specification for e.t. and weight (see Class Requirements). SFI Specifications may be purchased from the SFI Foundation (sfifoundation.com, (858) 451-8868); SFI Specifications are not available from NHRA Technical Services.
#93
You can run the rocker bars first, then mount the main hoop on top of the rocker bar. That saves from welding 2 extra plates.
#94
This is correct. Mine was done like that in the pics because I did it wrong and had to add the bar. If I were to do it over, I would have had the hoop on the rocker bar. Cool thing is, I can still use the rocker bar for my 25.5 cage I am working on now. All I have to do is add a small bar to connect the rocker bar and main hoop.
#95
When I decided to do the 10 point I wanted to make sure I did it right so I spoke with an NHRA cert guy before I did it.
#96
not if your cage is done and built to last years spec. mine is done, including the sill bars from hoop to a-pillar uprights. that is whats fooking me from doing this bar.
#97
must be nice to get sponsored, i guess its hard when you don't deal with shops though.
jc95148
02-28-2013 03:01 PM
mynameizstitch
08-25-2009 07:03 AM
