Putting the Bseries vitara's to the test
Nippon racing makes 81.5mm cast pistons like the Vitara's which should hold 400-500hp no problem since the Dseries are already well past.
The problem with the Nippon pistons is that they do not come with wrist pin locks or the grooves for them. But I fixed that issue. Here is a set I just did where I machined in spiral lock grooves so they now have full floating wrist pins. http://i16.photobucket.com/albums/b3...s/DSCN2231.jpg http://i16.photobucket.com/albums/b3...s/DSCN2233.jpg Of course 400-500hp on the stock block is a cracked sleeve waiting to happen. This block also got the CSS treatment to make sure the pistons fail first. http://i16.photobucket.com/albums/b3...s/DSCN2234.jpg Car should be rockin soon!!! |
Re: Putting the Bseries vitara's to the test
Be sure and let us know how long they last at that HP level.
Good idea there about cuttinga groove there. :thumbup: |
Originally Posted by 1992Si
(Post 39633801)
i wonder if they will b as good as the vitara's??
they look identical and ring lands are the same thickness, so unless there there lying about the cast aluminum there using they will perform just as well.
which cr are you gonna have with these?
:) Was planning on doing this to some 76mm pm7/p29z I have for my allmotor D to run eagles,but boozt bug bit me again (still plan to do those later tho) Let us know how it goez...
in for info. goodluck.
great build up, im sure you can put down some power with the vitara Bs
the nippon vitaras are NOT nearly as strong as the ycp brand vitaras, someone needs to get with ycp and have a set made...
the nippons look more like a stock honda piston than a ycp vitara, just a FYI... |
Originally Posted by jarvis199
(Post 39638990)
any idea what those pistons weigh compared to wiseco's or cp's?
tia :) |
I noticed that each piston is buffed on the left side- what is that for?
Originally Posted by trickeng
(Post 39633412)
Originally Posted by ef92b
(Post 39641213)
tia :) I noticed that each piston is buffed on the left side- what is that for? |
Originally Posted by boosted91crx
(Post 39641574)
HUH??? stock B18c sleeves can handle 500 for years, check it out my car makes 510 on 20 psi. after 2 years and over 16k miles and countless passes i decided to crank it up and see if i could get 140 mph, at 25-26 psi it cracked a sleeve, what happened was the 93 octane was well past its limit and it cracked from detonation. i still had to be close to 600 hp at that point and if i had used higher octane im sure it would have been fine. it still made 25 passes back to back in 95 degree heat before it blew lol.
(Post 39641574)
So what did you do? Do you weld the deck then CNC water pass through holes and deck the block?
(Post 39641601)
Thats what I'm hoping the CSS helps to prevent.
Originally Posted by jsilva
(Post 39641596)
Theres tons of people who take stock sleeves past 400-500hp with no problem.
Originally Posted by JDogg
(Post 39641906)
there are even more people with cracked sleeves at that power level.
Originally Posted by jjspec
(Post 39641867)
as for people running 500-600hp regularly for long periods on stock block. there are probably 100 people for ever 1 who crack a sleeve at 400+hp.... this process is to help the motors in the 4000-500hp range survive some detonation. [QUOTE]i got news for yah if you detonate as much as i did them cast pistons are gonna shatter taking them nice sleeves with them [QUOTE] and what is your experience with this type of cylinder support that you can so confidently state such a thing? i at least know its a better option than a blockguard, but how much is yet to be seen. ??? so we wait and see. |
Cool, that looks like a nice design.
like trickeng said, for ever 1 that works at 500-600hp, there are 100 that blow with 400 or less. the tune is very important and helps but nothing can account for the fact that these sleeves were not designed for that and some are weaker than others.
hell i had a gsr motor blow a sleeve wide open on the pull on the dyno at less than 5lbs of boost at 5000 rpms. blew the damn end tank off the radiator. stock sleeves are a disaster waiting to happen. |
wow u guys have bad luck, i dont know any one who ever blew a stock sleeve at that low of power cept from detonation and lean tune ect.
| All times are GMT -8. The time now is 01:51 PM. |
