Personal Best Stock block N/A H2B 11.52@116 NSCRA Finals
#55
Re: Personal Best Stock block N/A H2B 11.52@116 NSCRA Finals
I think for my power level and powerband, the 4.7 is perfect.
If i do gain a good amount of power soon, ill consider going to a 24.5 tire and 4.9FD
thanks Joone
thanks Joone
#59
i could vouch for the car. iv seen it running a a k2420 built and it was a good run props to jaywest
#60
#64
Cool man thanks.
Sorry if i didnt catch it.
What injectors are you running? What is your fuel pressure @?
#69
very nice numbers!
are you still using the stock t-belt tensioner or have u converted to manual ?
#72
Stock block or stock bottom end? Stock crank, Stock Pistons and rods??? Congrats if thats the case! Why bother building!
#73
I'd like to. Not sure if I will be able to make it though. Its kind of far. But hopefully I'll be there
thanks
#74
#75
Any idea what are all the parts required to convert from auto to manual tensioner setup?
Here's what i've listed so far:
manual t-belt adjuster bearing (14510-PT0-004)
t-belt adjuster spring bolt (90015-PT0-000)
t-belt adjuster bolt (90016-PT0-000)
I'm going to get rid of the balancer shaft as well in favor of the Kaizen kit.
Anything else I need? I just want to make sure I'm getting all the required pieces since I still need to buy them overseas. They're not available from the local dealership.
TIA
TIA
