ATI super damper?
ATI super damper?
I know its kinda like a noob question, but do I need a special tool to install one of these dampers its going on a b seires motor. Or it goes in like a stock damper thanks.
Re: ATI super damper? (integraboosted)
the ati damper is a very tight fit. i have never used a press or anything to install one, you should be able to get it on with the oem bolt, just be sure its going on smooth, otherwise you will end up galling the crank snout and the hub of the damper, and that is no bueno.
Re: ATI super damper? (ninesecrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninesecrx »</TD></TR><TR><TD CLASS="quote">You will only need a puller to get it off...otherwise like what was said above.</TD></TR></TABLE>
what he said
what he said
Re: ATI super damper? (turbotypeR@SPEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR@SPEC »</TD></TR><TR><TD CLASS="quote">
what he said</TD></TR></TABLE>
yeah what he said
Re: ATI super damper? (714phil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 714phil »</TD></TR><TR><TD CLASS="quote">
yeah what he said</TD></TR></TABLE>
yup, he said it
yup, he said it
yup, he said it</TD></TR></TABLE>
he sure did say it
he sure did say it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraboosted »</TD></TR><TR><TD CLASS="quote">I know its kinda like a noob question, but do I need a special tool to install one of these dampers its going on a b seires motor. Or it goes in like a stock damper thanks.</TD></TR></TABLE>
All that they said but if I was you I would take a dab of lubricant and rub it on the crank snout and ease it on.
Re: ATI super damper? (freakyty2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freakyty2 »</TD></TR><TR><TD CLASS="quote">
All that they said but if I was you I would take a dab of lubricant and rub it on the crank snout and ease it on. </TD></TR></TABLE>
You can't ease it on, they are a press fit. It has to be that way in order to take vibrations out properly.
I always use some anti seize between the crank and pulley, just so it doesn't get stuck. Says to do so in the instructions from ATI
Re: ATI super damper? (tony1)
i use anti seize too........use the steel hubs, stay away from the aluminum ones. i have seen a few issues with those...never a problem with the steel.
ive used both the fluiddamper and ati on my car.
Re: ATI super damper? (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged »</TD></TR><TR><TD CLASS="quote">i use anti seize too........use the steel hubs, stay away from the aluminum ones. i have seen a few issues with those...never a problem with the steel.
ive used both the fluiddamper and ati on my car.</TD></TR></TABLE>
Yep Fluidampr aluminum rounded out on me, I have a steel ATI now
You can't ease it on, they are a press fit. It has to be that way in order to take vibrations out properly.</TD></TR></TABLE>
I put lube and got in on a little and took my airgun and slowly eased it on with air sorry I didn't specify it. Small burst with the gun until it was flush and then torqued.
I put lube and got in on a little and took my airgun and slowly eased it on with air sorry I didn't specify it. Small burst with the gun until it was flush and then torqued. </TD></TR></TABLE>
Gotcha, yeah...it does not take much, but they will not go on by hand. The bolt works great to pull them on.
D Tranny Guru
Mike, you happen to know the crank snout diameter for a B series?
I've got a spare crank pulley here, SWORE it was off a SOHC, but it has a 28mm bore.
LS maybe????
Thanks.
LS maybe????
Thanks.
Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">Mike, you happen to know the crank snout diameter for a B series?
LS maybe????
Thanks.</TD></TR></TABLE>
28mm would be a B series pulley. I think single cams are 24mm.
LS maybe????
1 Post
Re: (Mista Bone)
BTW: ATI gonna make a D Damper?</TD></TR></TABLE>
they can make it if you need to. We've had custom Pulleys made in the past.
Re: (ExospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExospeedAMcrx »</TD></TR><TR><TD CLASS="quote">
they can make it if you need to. We've had custom Pulleys made in the past.</TD></TR></TABLE>
Custom ones are pretty pricey though, but they can make anything there...pretty neat company!
1 Post
Re: (ninesecrx)
Custom ones are pretty pricey though, but they can make anything there...pretty neat company!</TD></TR></TABLE>
yup they are. but if someone really wanted it, be prepared to pay the price.
D Tranny Guru
Good to see you around Wil!!!!!
You likely saw the Mercedes SC I'm adapting to where the AC used to be. Well the stock pulley on the crank wasn't big enough, could only spin the SC to about 11,000 rpm with engine @ 7500 rpms. Need 2:1 drive ratio.
Then while going thru an autoparts online auction, I cam across a universal AC mount, comes with 6 rib tensioner, just the the SC clutch/pulley......so I'd need a larger than stock 6 rib pulley
upper AC tensioner will no longer be needed
yes, that lightweight pulley is just for mock-up
