Max compression in turbo/high hp build?
Anyone try 12:1+ in their turbo build?
11:1 right now, and 900+hp. Plugs look good, logs look good, car feels potent...
Doing a back up motor, head, and cam package to swap in once my current motor blows, all with better components... Considering going 12 - 12.5:1 since it seems I still have a decent safety window on my 11:1.
Just curious if anyone has opted to try and go with something out of the normal 9-11:1 range, and if so did you pick up any notable power? Any regrets?
Re: Max compression in turbo/high hp build?
are you running a b or k? If you have the airflow you will make power. I know a lot of the sfwd b series guys are running over 12.5. I've heard 15 in one car but I just can't see that on vp gas. But more compression is the only way to make any more power on the 72mm.
I'd love to run around 12 but it's a street car and q16 isn't cheap.
I am currently running a 10:1 motor, but it seems like I remember Chris Miller running something around 12:1 years ago. Most of those guys don't post here anymore, so it's just speculation anymore.
I was told from a Tx tuner that T1's car was 14:1 at one point, but even if that were true, I'm just a garage built weekend racer, and cant afford to even attempt riding that thin line so closely.
On 11:1, I feel like I have a bit of leeway/window with compression to play with. I assume a bunch of the top sfwd guys are in that 12.x range that you mentioned, so just curious if any with experience had any input.
@bauergold: I'm running sealed ethanol.
Most of the cars out there at that power level are not 14+:1 compression, that's for damn sure.
The right turbo is a much more important choice than compression. None of my motors are anywhere near 14:1 or even near 13:1 for that matter. You'd be surprised to see how simple they really are.
Now the next block will be a bit more custom.
I will say this, I am pretty close to the 1100whp on a 6870 and am currently at 9:1 on steel rods. My block was done with all off the shelf parts from Real Street Performance. No special piston or coatings, no custom rods, nothing.
hey I read in another thread that you used to have the Liberty faceplated gearset. Would you recommend them for a 750whp 2500lb car? Not sure if they are worth it or if I should just save up for a dogbox. It's still something that is driven on the street. Don't really want to turn it into a race only car because of the weight. Just don't feel like dropping a grand and having them blow part too. Any other drivetrain mods you consider must have? And opinion on the trans brace/mid plate?
