Largest slick for stock fenders EG
Looking to see if anyone knows the largest slick I can run with stock fenders on an Eg coupe w Ktuned suspension. Thanks for any input. |
Re: Largest slick for stock fenders EG
I ran a 23X8X13 slick form M&H without contact on lensos. It was close personally I would not go any bigger, without a front end. Its not worth the fender cutting the slick at 130mph and smashing into the wall.
depends on a lot of things... you could fit 30in slicks or you may only be able to fix 10in slicks
9 inch wide slick is pretty the max that you could install whitout any problem(stock eg-ek fenders)...8 inch its no big deal!Keep in mind that your ride height is another key factor.
was running 13x8x24.5 on 13x8 inch wheels for 6 years,this season 13x9x24.5 on 13x9 wheels.. |
pretty standard to run lenso and 24.5x8 on stock fenders
I ran 24.5x8x13’s but if the car is to low it will hit. I recently changed over to 24.5x9x13’s and that was a breaking point and I had to modify things to be able to use correctly unless I raised the car to stock ride height |
I run 25x8.7x13 i have about a inch and a half gap
