Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Drag Racing (https://honda-tech.com/forums/drag-racing-36/)
-   -   how are you locking vtec when degreeing cams? (https://honda-tech.com/forums/drag-racing-36/how-you-locking-vtec-when-degreeing-cams-2947500/)
hello1320 Jun 14, 2011 05:57 PM
How are you guys locking vtec when degreeing camsAlso how the hell are you supposed unlock the pins with out taking the cams out and scewing up everything that u just did
JJsMotorsports Jun 14, 2011 06:36 PM
Re: ?
T1 has a tool that works good you may want to call them tomorrow.
Divers Jun 14, 2011 09:33 PM
Re: ?
Why would taking the cams out screw things up? Adjust the gears to where you want your centerlines, then pull the cams out, put the rocket pins back to stock, then put the cams back in. Done.
To lock vtec, I put a small ball bearing in the end of the rocker then put the pins back in then set the lash to 0 and degree away.
hello1320 Jun 14, 2011 09:46 PM
Re: ?
That's how I do it now. are you sure that accurate enough ? Differences in belt tension even makes a difference
wolve Jun 15, 2011 02:15 AM
Re: ?
degreeing just puts you in the ballpark, dyno/track will tell where the setup likes it best...
belt tension should be similair in between cam swaps
cibao2ner Jun 15, 2011 02:53 AM
Re: ?
the bolt on the left u put air presure n it locks vtec...there a video on youtube by a member here...https://honda-tech.com/forums/all-motor-naturally-aspirated-44/my-b20vtec-revised-2858137/ go tru that thread..
SPOOLINmatt Jun 15, 2011 04:45 AM
Re: ?
why not just put the gauge tip on the vtec rocker. thats what we do. I dont know how many different types of gauges there are though.
turbotypeR@SPEC Jun 15, 2011 04:50 AM
Re: ?
All you have to do is swap the vtec pins in the rocker arms and it will be on the high cam.
Honda Bull Jun 15, 2011 08:05 AM
Re: ?
LOL. Exactly. People are over-complicating this. Honda provides you with the parts to use from factory. Just reverse them.
hello1320 Jun 15, 2011 09:16 AM
Re: how are you locking vtec when degreeing cams?
That would work...... but it doesn't cause the dial is on the return rocker
TiALI Jun 15, 2011 09:48 AM
With compressed air and Honda air stopper tool, Worked great!
SPOOLINmatt Jun 15, 2011 10:17 AM
lol. all of this is over complicated.
a1320addict Jun 15, 2011 11:07 AM
lol, fact.
use even a m4/m5 lock washer, set lash to 0, and you're set.
hello1320 Jun 15, 2011 11:18 AM
Sorry I've only Degreed vtec killers.... so I havnt had to lock anything
xenocron Jun 15, 2011 04:52 PM
I would like someone to explain to me how differences in belt tension could affect valve events and when they occur?
I'm not being difficult either...I hear this a lot but no one can give me an explanation.
NAH2B Jun 17, 2011 05:24 AM
belt tension does not effect timing. any slack in the belt is on the back side near the tensioner/waterpump. the relationship between the crank and cam gears stays the same (front side).
the only thing that would effect timing would be a stretched belt.
like someone mentioned earlier i dont see why you couldnt degree and check lift by setting up your indicator on the vtec rocker if using an adjustable magnetic indicator but you wont be able to check p2v w/o locking the rockers together. alot of us use the belben degree kits and the indicators are fixed and set on the small lobe rocker.
locking vtec is very simple. just swap the pins or use a couple small flat washers behind the pin. the belben kit comes w/ tiny bearings to use but i throw those in the trash before they end up somewhere they shouldnt be.
xenocron Jun 18, 2011 07:12 AM
Nicely put Randy...
And I learned something new about swapping the pins...I too am always worried about dropping a BB in the motor, yikes!
sheepey Jun 18, 2011 07:17 AM
Good thread...
Divers Jun 18, 2011 04:17 PM
Re: ?
This might work to get you close to a centerline, but you can't graph the cams or get any values this way.
rainmanef Jun 20, 2011 01:30 PM
sorry if this is a stupid question but why do this? and when would you want to do this?
turbo-2nr Jun 20, 2011 02:32 PM
to degree your cams in and check piston to valve clearance
xenocron Jun 20, 2011 02:39 PM
#1 reason, most cams are made in China
#2 every motor is different, there are tolerances in manufacturing...and when you are running big cams, tolerances in your motor get smaller. Knowledge is power and checking and degreeing your cams allows you, your builder and your tuner KNOW that everything is on point, rather than guessing or saying "good enough"
#3 even on "stock" cam or "drop-in" cams your timing can be off if the head or block is milled or you have added a thicker headgasket
#4 because why buy adjustable cams and set them to 0, 0
#5 because you want to make the most power safely
When would be EVERYTIME you assemble a new motor preferably (speaking as a tuner)
rainmanef Jul 20, 2011 06:03 AM
thank you sir. learned something new today
KeseK24RSX Jul 21, 2011 04:00 AM
Yes sir. Agree w/ that last line 100% EVERYTIME you assemble an engine.
95exdsmkilla Jul 21, 2011 10:50 AM
this i highly disagree from personal opinion.
I don't think there's a vocab "safe" in drag race. lol just me though.
