Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Drag Racing (https://honda-tech.com/forums/drag-racing-36/)
-   -   hondata users (https://honda-tech.com/forums/drag-racing-36/hondata-users-2457039/)
dome Dec 22, 2008 02:59 AM
hondata users
ok right now i have fast ems in my car and im going to take that out and put the hondata s300 in it. its a p28 ecu. my car is a 92 95 eg.what i wanted to know is what harness do i use since there is no factory harness in there and what is have to do to get this working.
Boner_Ben Dec 22, 2008 03:05 AM
Re: hondata users
Do you still have your factory interior harness with ecu plugs? If thats the case you will just need any obd1 harness. If you got rid of all that when you did the FAST, might be easier to grab an OBD2 harness with an OBD2-->OBD1 Jumper Harness and run it straight to the ecu and then wire up your interior stuff seperatly.
htx_jr.95eg Dec 22, 2008 08:33 AM
Re: hondata users
your best bet would be to put your interior harness back in there
havok hybrid Dec 22, 2008 10:20 AM
Re: hondata users
you can run a (99-00 SI ) obd2 B engine harness.. it plugs directly into the ecu.. Just needs power and ground...
I did this on my 94 integra... only took 3 wires to make it fire..
Ignition power
Fuel pump power
ECU harness power.
Its clean and simple.. Look into it.
nonvtecallmotor Dec 22, 2008 01:55 PM
Re: hondata users
Why are you down grading ECU? Leave Fast in there. It works why change it? You have one of the best tuners around tuning on the car it would be dumb to have someone else mess with it.
Garcia-Racing Dec 22, 2008 02:29 PM
Re: hondata users
I love the FAST unit. Never had a problem with it.
dome Dec 22, 2008 04:10 PM
Re: hondata users
Well i never had a problem with it at all. I dont think its a down grade.I would still try to get Jason to try and tune it. I feeel like the s300 has more features and options on it.
nonvtecallmotor Dec 22, 2008 05:51 PM
Re: hondata users
Hondata does have a few good built in option that the Fast doent have in your model but, theres other ways to make it happen with the stuff that you currently have.....
You know if you need any help just hit me up.
newtype_33 Dec 22, 2008 06:17 PM
Re: hondata users
yeap s300 got a lot feature never had a problem i`ve used s100,s200 from the past never had any problem i love hondata.
