HIBOOST SFWD BUILD 1 OF 2
well i finally decided to make the hatch more of a track car and to hopefully come out and play in the "sfwd class" as soon as possible.
please enjoy and yes im keepin the STOCK FRONT..... and stay tuned for more pics as we progress on the build
mounts
avid solid mounts
block
golden eagle sleeved gsr block
83 mm cp pistons 10:1 w/ upgraded wrist pins
manley turbo tuff rods
gsr crank
head
complete ferrera valve train
skunk2 tuner 2 cams
stock port (maybe later i'll port the head)
gato performance intake manifold w/ 8 injector setup
Q45 Throtlebody
custom top mount manifold
Precision Billet gt42 72mm turbo w/ a up pipe
Tial blow off valve
precision 66mm wastegate
3" aluminum piping
vibrant's 3" vanjen clamps
tranny
G-force gear box
G-force shifter
Clutch masters 725 series twin disc clutch
DSS 5.9 level axles
Quaife differential
fuel
FCS Fab 5 gallon fuel cell w/sending unit
weldon 2345 pump
weldon 2040 regulator
ignition
AEM v2 ecu
AEM twin fire ignition box
AEM pencil coils
AEM epm
suspension
strange engineering shocks and springs
spc front camber kit
Blackworks Racing lower control arms
Blackworks Racing Rear Sub Frame Brace
wheels
weld racing slicks 13x10
weld racing skinnies
and can't forget the cage
Ken's Kustom 10pt
fabbed and welded by kevin maecha
mounts
avid solid mounts
block
gsr crank
head
skunk2 tuner 2 cams
Q45 Throtlebody
Tial blow off valve
3" aluminum piping
tranny
G-force gear box
G-force shifter
DSS 5.9 level axles
Quaife differential
fuel
weldon 2345 pump
ignition
AEM v2 ecu
AEM pencil coils
AEM epm
suspension
wheels
Ken's Kustom 10pt
Re: HIBOOST SFWD BUILD 1 OF 2
Sickkk. I really like this car .. Good that it's going to be legal and competing. I seen a low 10 sec pass at like 80mph a bit back, would have liked to see a full pass. Goodluck with the build.
The intercooler is a Garrett 4.5" core the turbo is a divided housing but the manifold isn't.... I'm only doin this setup because I'm using the stock front end and the space is limited with a afi, fullrace, twin scroll top mount
It will be running ASAP it all depends on money.....
Aki and bams were the ones who ordered it I really don't know...... I just told them the specs that I wanted and they got it
Btw it's a Garrett core 24x12x4.5
Kevin from endless motorsports in little ferry Nj
Im lookin to get about 150lbs
