fuel pump
will the new dw300 or the aeromotive 340 intank make 650hp? thats all i want this year next year i will be a fuel cell so i will need a new setup
Re: fuel pump
Originally Posted by slowboy90
(Post 44607088)
Re: fuel pump
yeah a buddy of min pushed his... it was a sad day :(
Re: fuel pump
what about the 340lph aeromotive it should make 650 easily next year im going fuel cell and a new motor
Re: fuel pump
What kind of fuel are you looking to use? I don't see 650hp on gasoline being an issue. E85 would be stretching it on either pump.
Re: fuel pump
pretty sure i will be running 116
Re: fuel pump
(Post 44611531)
340/255 - 1.33 or 33% more or around 730 hp give or take. |
Re: fuel pump
Will 2 intank DW300 Pumps Make 700whp whit E85?
Re: fuel pump
Yes, 2 DW300 pumps should be able to support 700whp on E85.
Re: fuel pump
Well i am having trouble getting the 340 intank and also was told it may not support my power so im going to do the old trusty walbro intank which i already have installed and a bosch near the rail but jays racing has pumps they say outflow the bosch inline im looking for some insight?
Re: fuel pump
Why not do a intank 255 and inline 044?
Re: fuel pump
thats currently what im thinking about doing i have a 255 intank
Re: fuel pump
You should be able to support that much power on gas.
What issues are you having with the install? |
Re: fuel pump
(Post 44663562)
Re: fuel pump
well i will be running 1600's im going to be running 25 psi of boost
Re: fuel pump
You'll need ~260LPH of fuel to support your hp goal. ...and with the size of your injectors, you can afford to run a lower baseline fuel pressure. With your baseline around 40psi and 25psi boost, you should be hovering around the 65psi fuel pressure range at full bore. Our pump should be able to handle that. I'd imagine the 340 should be okay, too.
I'd just hate to see you scrap what you have when what you have should handle the job. |
Re: fuel pump
wel;l thats why im asking if a walbro and a bosch will do ill keep the walbro and upgrade next year
Re: fuel pump
what 1600cc injectors do you have?
Re: fuel pump
i dont have them yet i currently have 1000cc and im going to idle the car on them again before i go dyno again with the new headgasket
| All times are GMT -8. The time now is 12:15 AM. |
