Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Drag Racing (https://honda-tech.com/forums/drag-racing-36/)
-   -   DSS 2.9 Axles Question ? (https://honda-tech.com/forums/drag-racing-36/dss-2-9-axles-question-2572896/)
NewKlear May 20, 2009 11:30 AM
who in here has run the dss 2.9 axles with more horsepower that they are rated for(475 whp)?
SD_Lurker May 20, 2009 11:55 AM
Re: DSS 2.9 Axles Question ?
what's your question? Are you wanting to know if they can really handle that power? People make that kind of power using stock axles.. Mind you they may not be launching on 26's but it works on the street..LOL
NewKlear May 20, 2009 01:00 PM
well i went to the track and first time on slicks (24.5x9x13) and launched at like 3000 rpm and snapped a axle. push it and changed it at the track but i don't want to go thru that again so i want to upgrade. i want to launch hard.
JayWest May 20, 2009 01:13 PM
you launched at 3k on slicks?
hmm
NewKlear May 20, 2009 01:22 PM
yeah because i was scared to break a axle. just wanted to know if anybody out drag racing is using dss 2.9, but their car have more horsepower than what the axles are rated for?
boosted91crx May 20, 2009 01:27 PM
i have the dss axles 2.0 before they made the 2.9 and i am 510 to the wheels using 25 inch slicks launching at 7k, the 2.9 are even stronger, the reason you broke is you dead hooked, the trick its to preload like crazy and spin some not dead hook.
NewKlear May 20, 2009 01:32 PM
i have 520 whp right know so i was thinking to get the 3.9 but someone told me to run the 2.9's. im a newbie right now and need to learn how to preload. i just want to launch hard really without worring abot snapping axles.
boosted91crx May 20, 2009 01:35 PM
2.9s will handle 520 if you preload.
newtype_33 May 23, 2009 07:51 PM
i`ve seen people using stock axles running 9`s
NewKlear May 23, 2009 09:11 PM
wow i really need to preload! lol. can't wait till my axles get here so i can go the the track.
ExospeedAMcrx May 23, 2009 11:05 PM
what was the tire pressure on the slicks?
locash May 23, 2009 11:38 PM
My k-series street driven Integra was making around 500hp, many 8k rpm launches on slicks with the DSS 2.9's.. For the money, those are great axles.. In my drag car, I'll only run DSS 5.9's..
96 GSR-T May 24, 2009 06:24 AM
If you are worried about breaking axles launch higher, you want to spin not hook off the line.... I launched at 7500rpm no 2 step on stock axles with 8psi in the tires for fear of breakage.
NewKlear May 24, 2009 07:31 AM
i had the psi at 9.
insanemike24 May 24, 2009 08:06 AM
why not use INSANE SHAFTS can support the horse power easily with the tire pressure down to five pounds These are an even swap axle, which means no spindle change Much lighter than any other axle on the market Will be very happy with your launches and your 60fts. and about half the cost of other manufacturers
boosted91crx May 24, 2009 08:42 AM
maybe cause dss are tried and true verses never even hearing of insane axles which probably are the same as gator glens "high hp" axles.
insanemike24 May 24, 2009 09:18 AM
INSANE SHAFTS are original and copies nobody They are proven just new on the market but feel free to use whatever axle you feel will work for you
fanaticalK May 25, 2009 12:44 PM
I think the 2.9's are worth their weight in poop.
I snapped the driver side nub clean off in mid burnout, no it did not start to wheelhop. Matter of fact, it looks identical to the picture in their foresale thread showing what happens to a stock axle. NOPE, that's what happens to a DSS axle.......and apparently the best 1 they can provide.
I didn't dead hook, dump clutch, or wheel hop. Its only 413whp in a d16 with a 26" DOT.
Rated at 475+whp.....please, they can't handle 400hp out a single slam on street legal tire.
96 GSR-T May 25, 2009 03:43 PM
26" Tires break stuff, cant completely blame your issues on the axles IMO
J.Berta May 27, 2009 04:33 PM
for real. 26's are the money makers! lol
boarding2008 Aug 29, 2012 07:32 PM
sorry to bump a 3 year old thread but it was one of the first with a google search. i have 2.9 DSS axles. car was tuned and made 280whp at 18psi(d16z6). i turned the boost down to 14 so im guessing 230ish now. first night at the track since tune and first time with a fwd turbo car. first run wasnt great because well, it was my first time. 2nd time. went from 1st to 2nd and SNAP. driver side axle, right near the transmission. 205/50/15 street tires. stock open diff.
is this normal for this to happen? it didnt wheel hop much my first run. wheel hopped more the 2nd time.
Hyper16-Johnny Aug 30, 2012 12:26 AM
Since you bumped, I'll add. I'm on the 2.9s without problems at 577hp. I have no traction bar, I'm on 24.5/9/13 MT's with 9psi, and stock GSR trans with ITR lsd. My 2-step is set at 7k, I preload, and then feather it out. I get no wheel hop and cut consistent 1.6 60s.
I think most people break their 2.9s thinking they have godlike axles and just dump the clutch. Anyone who drives that way is bound to break something...
JDMekB20 Aug 30, 2012 04:42 AM
i'm on 2.9's and i made 900+ with no issues so far (knock on wood)
surfingsk8r Aug 30, 2012 05:27 AM
I have run them at 683 whp in the past didn't break, but the trans did eventually. Preload the launch and they will last a lot longer.
DA 4 Lyfe Aug 30, 2012 08:13 AM
I'm runnig the DSS 2.9s trapping 140 in my street car on slicks with over 30 passes and no broken axle yet. (Knock on wood)
