Deleting Brake Booster, KKC setup
#27
HELLO,GOOD MORNIN'
#28
Re: Deleting Brake Booster, KKC setup
I should mention that my brake line broke due to rubbing, but still left me without any brake what so ever.
Here is how I did mine
and then ran the rear lines to the back brakes
#34
For you guys just running front brakes how does it stop? I'm in a very big debate to just run the fronts and for the rears put in a staging brake..
#35
Where did you get your lines? Also when you come out into the wheel well are you going into the stock mounting tab with a fitting or running straight to the caliper? Reason I asked is I have SS from the tab out if it would even be worth messing with or just run the line all the way
#36
matt im running mine just like above but to the stock changeover bulkhead in the wheel well. the lines above is goodridge -3 brake line. It cost me like 60$ in fittings. If i have some line left over this week ill just give it to you. Im pretty sure i have enough for my fronts and another civic's fronts. you just need a 10mm x 1.0 male inverted flare to -3 male flare fitting for the wheel wells.
#37
some people are saying dont use the rear brakes with this and some people say it's no issues. I'm wanting to know for sure before I run my setup for this year. right now I have the wilwood setup with the "t" so it runs to rear lines as well. should I change up and get rid of the prop valve and just run from the master cylinder to a "t" and then to the front brakes without the rear brakes hooked up at all? I'm on skinnies in the rear.
#40
#41
#42
im doing the same the right now to my integra. going straight to the calipers in the front and rear are staging only
#43
I have no experience with using only front brakes on a car. My car is not going to be a complete race car. It will certainly see some time on the streets. I am assuming that I should run rear brakes on a street car, however, the car is not going to be that heavy. Not really building it for any certain class so it may not be as heavy as some of your cars. I know that I have read or heard of a couple street cars with only front brakes, but as I said, I have no experience with that at all. What do you all think? On the street I should not have skinnies on the back, but at the track I may run some at some point. I am thinking that I need front and rear brakes plumbed from the MC and prop valve.
#44
Thanks, just holler at me if you think your going to be able to spare some. Most of my stuff will not be here till next week.
#45
so if we do just the front brakes off the pedal then we just T off the MC straight to the front brakes without any prop valve?
#47
sorry to bump an old thread but I'm setting up a boosterless system, thinking about the wilwood 3/4" master. My question is...How's the pedal effort compared to a stock system? Is it drastic like if you were to lose all vacuum on a stock system or is it minimal that you can correct yourself in an emergency maneuver?
#48
1 Post
#49
ok so, ive had to wrap a rag around the reservoir and zip tie it because everytime i stop after a run i get fluid sprayed on my firewall paint. I can not figure out where its coming from. All fittings are always dry, hose is tight, and it seems like i can't find any wetness even on the reservoir. But after i wrapped the reservoir it stopped spraying on my firewall. Anyone encountered something similar?
#50
I just picked up a car with a manual setup... must say its taking some time getting used to on the street.
I'm trying to get down the track in a few weeks, that will be a different story.
Sounds like you guys aren't having any issues thought at 135+mph? Just curious, what is the point of running without a booster?
