Slick roll out?
Old 02-07-2012, 02:10 PM
NABeastRR's Avatar
Default Slick roll out?
I just got my first set of slicks and one is 72" and the other is 72 5/8 is that too much of a diffrence? ALso ive read that you can blow the smaller one up, let it stand for a bit and recheck the roll out. That it may stretch it?
Old 02-07-2012, 02:14 PM
hello1320's Avatar
Default Re: Slick roll out?
Yes and yes
Old 02-07-2012, 03:00 PM
NABeastRR's Avatar
What PSI should I inflate to and how long should it sit?
Old 02-07-2012, 03:19 PM
tepid1's Avatar
Read this
http://www.mickeythompsontires.com/tech.php?bulletin=s8
Old 02-07-2012, 03:55 PM
NABeastRR's Avatar
It doesnt state how long to really inflate it to try and stretch it. Wondering if any of you guys have real world experience and if this is within the "stretching limit"?
Old 02-07-2012, 05:53 PM
hello1320's Avatar
Just try it.... There's no textbook....it will be different with every tire
Old 02-07-2012, 05:56 PM
hello1320's Avatar
Use a piece of string.....not a tape measure...also putting the tire in the sun while its inflated helps a little
Old 02-08-2012, 03:20 PM
NABeastRR's Avatar
alright man thanks alot ill try it out and see how it goes & post results.
Old 02-08-2012, 05:36 PM
theidealone's Avatar
I never feel comfortable putting over 25psi in mine. 30 would probably be fine.
Old 02-11-2012, 06:32 AM
NABeastRR's Avatar
Well I messured myself instead of going off of what was on the tires and I got 72 even and 72 3/16. I aired the small one up to right at 30 psi let it sit in the sun for about 30-35 mins. let her down and re messured and it was dead one by the eye laser so it did work!!!
I guess I got lucky on perfect timing and PSI in the tire. Good luck to others who may have to do this and hope this helps someone in the future.
honda_racing101
11-01-2006 06:40 AM
Thasty
Honda Motorcycles
06-25-2004 12:06 AM
Motorgroove
14
01-27-2004 12:06 PM
Dan GSR
10
01-25-2003 11:14 PM
davidnyc
04-18-2002 04:33 AM
Quick Reply: Slick roll out?
