Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Drag Racing (https://honda-tech.com/forums/drag-racing-36/)
-   -   Car will not leave, bogging (https://honda-tech.com/forums/drag-racing-36/car-will-not-leave-bogging-3206785/)
89efhatchy May 9, 2014 06:29 AM
2130# car, on 24.5's, builds 12-14# on 2 step. I've tried leaving at different rpms anywhere from 6000-7000rpms. Last night it bogged from 7000 and broke the bell housing so I didn't get to try any changes. I do my burnout in 2nd using the 2 step and it does fine. I can't figure out why it's bogged four times in a row. Any ideas?
http://img.photobucket.com/albums/v6...ps0ba91b90.jpg
http://img.photobucket.com/albums/v6...ps1f13140f.jpg
civic-steve-94 May 9, 2014 07:04 AM
Re: Car will not leave, bogging
I'm running on 23" m&h and @ 7.5psi-8psi in the slicks I leave at 8100-8200rpm @ about 8psi from the turbo
89efhatchy May 9, 2014 07:58 AM
I don't think it's a matter of not enough boost or rpm. I think there's something going on with the antilag not coming off soon enough. That's why I posted the screenshot of the two step and antilag. Anyone that's familiar with setting that up see anything wrong with it?
89efhatchy May 9, 2014 08:00 AM
I had 10# in the slicks also so there's no reason the car should be bogging.
Tippyman May 9, 2014 08:03 AM
If you're datalogging 12-14 lbs, then I'd say it's working. Try leaving higher.
turbo-2nr May 9, 2014 08:13 AM
You could try bringing the mph down, but we normally leave it around 10mph and let the car ride out on it, how do the logs look, anything strange, what system is that dies it not have an activation and caut point
Tippyman May 9, 2014 08:17 AM
Looks like neptune.
89efhatchy May 9, 2014 08:19 AM
Yes it's Neptune. I haven't logged it at the track. Internal logging never seems to work for me and I didn't want the laptop sliding around in there.
89efhatchy May 9, 2014 08:21 AM
The reason I don't think it's rpm related is because the first time I took it I the track, it blew the tires off leaving around 6000. I'm not sure what changed.
turbo-2nr May 9, 2014 09:14 AM
Just a theory, possible ignition problem in the dash, kills the car, IV seen it happen, with the car running beat on the steering column
98vtec May 9, 2014 09:21 AM
Log timing and fuel. Very possible you are reaching a section of the tune upon unloading which needs to be adjusted.
I have seen loose harness pins at the ecu cause problems as well which is why I typically run hot glue on the back side to keep the pins secure. Not saying that's the fix but launching at 7000 is a pretty big jolt.
Let the engine idle, pick up the ecu and lightly shake it. If the idle stumbles then you know it's at least possible.
89efhatchy May 9, 2014 09:40 AM
Okay cool. Both good points. The car did have an issue on the dyno where it lost all power. We found the problem and fixed it but maybe it's giving a problem again. I'll check that out.
lvdb-2 May 9, 2014 04:29 PM
what was the problem you had the dyno if you care to share I also had a prob when on the dyno with my alternator, and I seem to be having the same issues with the launch control.
89efhatchy May 10, 2014 10:09 AM
Whoever had the car before me relocated the fuse box under the dash and the terminals on the power wire they used had corroded and was barely connected.
SwappedTURBOegg May 10, 2014 12:35 PM
my off speed is 2mph if that helps
Blown90hatcH May 10, 2014 06:11 PM
Are you transitioning into the high speed cam table and the car is going lean in an area of the map that you hadn't been hitting?
89efhatchy May 11, 2014 04:58 AM
That's a good question. I figure once I get the bell housing swapped out, I'll datalog it on the two step and launch it a few times.
