bad 1/4 mile time
i went to the strip this weekend and ran horrible time i have an ef with a b16a1 and could only run 16.2 it bone stock i had a friend with same motor and same car and he ran 15.6 any suggestions
Re: bad 1/4 mile time (efwheelwhore)
he probably drives better than u
come on now my buddy has a bone stock zc in an ef hatch running 15.1, thats right a dohc D series. so it sounds like theres something wrong here...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efwheelwhore »</TD></TR><TR><TD CLASS="quote">i went to the strip this weekend and ran horrible time i have an ef with a b16a1 and could only run 16.2 it bone stock i had a friend with same motor and same car and he ran 15.6 any suggestions</TD></TR></TABLE>
learn how to drive. practice. let your freind who ran the 15.6 drive yours and i bet you the time will be WAY better than a 16.2 either that or your motor has serious problems... |
Re: bad 1/4 mile time (h22crxpwr)
as a matter of fact he ran a 17.1 when he drove my car and i drive pretty good
so drive his car and see if you can get a better number than him! https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emwink.gif
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efwheelwhore »</TD></TR><TR><TD CLASS="quote">as a matter of fact he ran a 17.1 when he drove my car and i drive pretty good</TD></TR></TABLE>
Then something is wrong with your car. You know this, what do you expect us to tell you that you don't already know? |
Re: bad 1/4 mile time (nsxmatt)
What's the mph? That'll determine if there's a issue with the car or your driving.
Re: bad 1/4 mile time (RaceProfessor)
84 mph at the end of the 1/4
tires??
84mph? It's not you, it's the damn car. 16.20 is on par with a 84mph trap on street tires. With a stock B16 you should be at least in the mid 90's trap wise.
Car:
95 Accord Lx 4 Dr (was auto) Mods: H22A w/ M2B2 OE LSD Fidanza 8lb Flywheel Underdrive Crank Pulley, No PS ES Front Inserts, F1 Stage 3 Clutch Stock Intake, Stock JDM Header Stock JDM CPU /w Speed Cut https://honda-tech.com/forums/images/smilies/emsad.gif Crower Stainless Exhaust Valves (3rd gear @ 8200 = Alot in 2nd) REV Racing 17" Gunmetals w/ Lip 2.5" Crush Bent Exhaust https://honda-tech.com/forums/images/smilies/emsad.gif w/ full Cat Oval Can w/ Dual Straight tips I Race with 195/55/14 steelies (bald) Weighs 3025lbs with me Time: React: .542 60 ft: 2.28 1/8: 9.7 MPH: 68? 1/4: 14.4 MPH: 97 With the Groceries https://honda-tech.com/forums/images/smilies/emwink.gif The Secret is in the Intake temp and underhood temp... |
Re: bad 1/4 mile time (H22A_CD5)
y'all both sucks at driving..!
Yeah .. I'd say the B16 is hurt, cause when I first ran my CRX (full weight) on 13" steelies I ran a high 15 or 16 flat but I definitely had a higher trap then that ..
