b18c5 11 sec build all motor
I have a Honda civic ek hatch (2100lbs)with a 97 b18c5 in it. I was wondering what parts I would need and what would cost be to run 11s all motor.
Re: b18c5 11 sec build all motor
large jet pack and many rolls of duct tape :)
11 seconds is moving...esp without turbo or nitrous. Good luck, even with a total high compression rebuild top to bottom |
Originally Posted by ShadyOne
(Post 49915785)
11 seconds is moving...esp without turbo or nitrous. Good luck, even with a total high compression rebuild top to bottom OP are we talking 11.00 or 11's as in 11.xx? Do you want to stay B or are you open to K series? |
You need to do some weight reduction and maybe put close to 10k into the motor without a tune.
Originally Posted by egidk
(Post 49916020)
(Post 49916020)
money talks
I am talking 11s and I already have the b18c5 so id like to use that.
Originally Posted by Ron Burgandy
(Post 49915821)
Wow ^^ welcome to the drag forum and thank you for that wonderful post.
^^wow! I wonder how many pipe dreamer come in here and say that very same thing! Seriously if money ain't an issue then find a reputable shop, drop off your car, and fork over some benjamin.
Originally Posted by frost_white_ej1
(Post 49916850)
Nitrous. Lots of nitrous! 11's all motor could be doable with a fat stack of cash into a build and a lot more weight removed.
11 sec all motor b series in a ek is do able....seen it with numerous cars already..stock sleeve b20 v on 85mm piston with 13:1 comp with a mild built head and cams with the right bolt on also...11sec with a b motor is do able.
Originally Posted by kurtrussell
(Post 49916937)
I only say that money isn't a prob because I am not trying to build this in one day. its going to be a long project but thanks for the help on the build troll. |
yeah, 11's all motor with no exhaust on a b18c5 is possible..
but it means the only thing about it that is still honda parts engine-wise is the block and the head. more than likely no exhaust and not driven with any frequency.. |
sleeved block, stroker kit, cnc head with big cams and good intake and exhaust setup. itll do it.
Go check out my thread from back in 2004. It is LSvtec, but still pretty close to what you are trying.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/217-whp-1-8-liter-dyno-chart-time-slip-video-inside-enjoy-1082748/ |
Originally Posted by backdraft
(Post 49917709)
https://honda-tech.com/forums/showthread.php?t=1082748 I don't see 10,000 dollar engine build going on there.. Still retains lots of oem honda parts no big dollar pieces in the build besides the ported head maybe! here it sounded like it would be a merricle to get a b-series into the 11's on a budget lol.. |
Ive seen plenty b18 on a budget running 11, no need for strocker kits or sleveed blocks
Originally Posted by Nonvtec eg6
(Post 49917865)
thank you all
