Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Drag Racing (https://honda-tech.com/forums/drag-racing-36/)
-   -   Anyone using Co2 on kpro (https://honda-tech.com/forums/drag-racing-36/anyone-using-co2-kpro-2970975/)
bads2k Aug 20, 2011 09:38 AM
I know the way boost control is through kpro is different than s300 how do you you setup the Co2 to work with kpro bbg? What regulator psi are people running off the bottle.
Turbogixxer Aug 20, 2011 10:07 AM
Re: Anyone using Co2 on kpro
K-pro does not know you are running C02, so it will not be a issue if you have it setup correctly in the k-pro software.
bads2k Aug 20, 2011 06:47 PM
I'm talking about using co2 for boost control to put psi on the gate. I'm wanting to change to a smaller spring but won't be able to run the psi I want up top without it. I know guys with s300 use it often but kpro doesn't have a few options in boost control like s300 does.
nonvtecallmotor Aug 20, 2011 07:24 PM
What hes is trying to say. Is Kpro doesnt know the difference because it doesnt read top port psi....
Using C02 will work.
Turbogixxer Aug 20, 2011 08:05 PM
:thumbup: Yep, just remember that C02 has alot more pressure then just using boost, so be careful with it.
bads2k Aug 20, 2011 09:53 PM
Ok thanks. Be carefull in what means? What psi should the regulator be set to then? It gas to be a bit more than the psi your wanting to run max correct?
