800whp and the 6266?
#26
Re: 800whp and the 6266?
Depending on the setup I don't see the .82 being much of an issue. We trapped top mph 157 on the T3 so if the car is lighter than my Integra tank it'll do 160 IMO no problem
The exhaust wheels flow very well on these turbos so back pressure isnt high. With a 6766 i think that statement would be different though
#27
Currently on a divided 1.16 T4 we're seeing little less than 1:1 ratio. From my understanding a 1.16 divided is about the same area as a .82 open t3 or very close.
#28
#30
If your going to get one and price doesn't matter get the gen2. It'll net you another 40 ish whp over the gen1 and its a ball bearing chra and likes higher pressure ratios
#32
I am considering running this turbo but would like a broader powerband as it will see moderate street time. How does your graph look in comparison?
#41
Torque should peak and flatten out when torque rises with rpm is boost creep or a leak or small springs in the gates and asking to much from the solenoid to make more boost or could be exhaust leak too among other things. These turbos come in and hold torque well to peak rpm.
If it spoiked better and got the peak torque earlier it would also make more overall hp
#43
1 Post
#47
1 Post
great numbers. really simple setup as well. this is getting me excited as im in the process of building two 6266 gen2 setups, both in midori green ek hatches
#48
#50
Stock port head
CSS block
1000cc
Hondata
T3 .82AR journal bearing
Wastegate spring was weak and wouldn't hold more than 29lbs. It made just under 780whp.
Pulled it back to be extra safe 750whp/490tq
Could have easily hit 800 with a heavier spring. Don't really want to make any more power as I'd like to keep the trans in one piece.
CSS block
1000cc
Hondata
