467whp, thought on trap speed? Low?
#51
Location: R.I.P Brian Arbogast...you will be missed, maryland, USA
Re: 467whp, thought on trap speed? Low?
You should just send it to John.. like I told u I think its cause of the gas u put in and the car could probably hold more boost in the lower gears with slicks. I'm sure John set it up for you using street tires.. I would suggest learning how to use the boost control in hondata so u can set all that up for yourself when your at the track. Make life a little easier on yourself.
#52
Yeah, took the car up to John last night and he installed the pwm components into the S300. It had the solenoid, but boost was only set through the tru boost which was most likely hurting the car a little. Dialed in the boost on the street. It builds full boost sooner and carrys it longer with little to no creep. Feels much better. Running strong. I've been working on figuring S300 out; this is my first car using Hondata.
CRXRageD
05-06-2002 08:27 AM
130, boost, chambersburg, dynno, falling, honda, innovative, motorworks, pa, quarter, shifting, trap, tuning, tunning, ycu
