24.5x9x13 slicks to much for 200whp lsvtec?
I have a close to 200whp lsvtec in my 96 coupe, first of all i would like to run the car on slicks, my brother has a set of 13in lenso with 24.5x9, that i could use, is this too much for my power level? Also what would i need to use them? Extended studs? Spacer? Thanks guys!
Re: 24.5x9x13 slicks to much for 200whp lsvtec?
There way to big use a 22inch slick an yes you need extended studs for safety but you can use them without , if ur coupe is a DX model the lensos will bolt right up without spacers
Way to much for your power level. I would suggest some 22" slicks my buddy just made similiar power be in it a more torquey H but the 22 seem to work perfectly fine it also depends on your final drive.
Thank's guys. Car is a 96 EX. Car has a 97 type r transmission
Pmd
ive used 23's with around the same power...worked fine
I just wanna know if it would work, just save me money from buying a set. If it would do more hurt than anything its not worth it to me
If thats all you got by all means use them , I would just put more air in them so there not so flat , An EX coupe you will need a spacers
