12.499 in allmotor street CRX
Last night I won the street class at a National Dragracing Club Denmark (NDCD) event. My start got messed up but I still clocked the best time so far. I got a 1.9 60 ft but had 1.80's in the other passes. My CRX is around 2200 lbs with driver but I would like to get down to 1.6 60 ft's. The only things I can improve on the car are to install traction bars and hard engine mounts. I'm only running inserts in stock mounts right now. What else can I do to get time down and what time can I run with that speed (112.82 mph)?
Video of the final: http://www.we-todd-did-racing....5NTQx http://www.honda-klub.dk/data/cache/...8be7.43013.jpg |
Re: 12.499 in allmotor street CRX (CRXEE8)
Sick. I think w/ a low 1.7-high 1.6 60' you could get into the 11's. Nice MPH out of that NA setup as well. What is your WHP?
Phil |
Re: 12.499 in allmotor street CRX (hondaguyef)
237 whp, 151 tq
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXEE8 »</TD></TR><TR><TD CLASS="quote">237 whp, 151 tq</TD></TR></TABLE>
I'm very impressed https://honda-tech.com/forums/images/smilies/emthup.gif That's sick! Setup? Phil |
12:1 84.5x89 B20VTEC
RLZ stage3 head Cams with Skunk2 stage2 lift and JUN3 duration JG Sheetmetal IM SMSP header Quaife LSD etc... |
I got a b16a in my crx and it runs high 11's in the 1/4! What type slicks you running?
Re: 12.499 in allmotor street CRX (fastasscrx)
M&H 22x8" at 8 psi
Same here, with 13" gold Lenso's, cant post pics cause they are too big!
fastasscrx = turbo?
Re: 12.499 in allmotor street CRX (XtraFastCRX)
Congrats on the time Henrik! https://honda-tech.com/forums/images/smilies/emthup.gif
Re: 12.499 in allmotor street CRX (DEVIOUS_EG*)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEVIOUS_EG* »</TD></TR><TR><TD CLASS="quote">Congrats on the time Henrik! https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE>
Hey Andy! How can I get the 1.6 60 ft's? I launch around 8k but not with launch control since oil comes out of my breather kit when I use that. I had tons of grib at this track so I dunno what I did "wrong" since my 60 ft's and not lower. Maybe I should try and get a longer 1. gear. My tranny setup is a Y2 from my EE8 with a 4.73 FD and Quaife LSD. I finish around 9k i 4. gear so I think that perfect. |
suspension straps for the front work wonders. also some stiff springs in the rear. hmmmm, you ran good times. Solid engine mounts is almost a must. I have a similar setup and i run consistant 8.0s with 1.75 60's at my local 1/8 howver i have yet to go back since my recent tune. I havnt run straps yet but this weekend i will. when i ran the straps before i was running 1.70's with 20in slicks. https://honda-tech.com/forums/images...s/emsmileo.gif and about 186whp.
Re: 12.499 in allmotor street CRX (turbociv)
Hey Andy! How can I get the 1.6 60 ft's? </TD></TR></TABLE>pm'd https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: 12.499 in allmotor street CRX (b19coupe)
Wowsers! awesome times man. Your mph are awesome, you can definitely see 11's. I'm happy for you as i have read about your build and i'm glad to see everything is working perfectly together. https://honda-tech.com/forums/images/smilies/emthup.gif
Re: 12.499 in allmotor street CRX (rjay8604)
Re: 12.499 in allmotor street CRX (Quitripin)
Thanks for the support guys https://honda-tech.com/forums/images/smilies/emthup.gif
To bad this was the last QM race this year so I will have no updates the next 6 months on the CRX. Oh well I have my K24/K20A drag EG I will be working on so that's ok https://honda-tech.com/forums/images...s/emsmilep.gif |
CRXEE8
I think better if you put tranny from Integra typeR JDM and gear set ATS 1,3,4,5 https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: 12.499 in allmotor street CRX (krystianitr)
Lower the tire pressure more. What gear are you doing your burnouts in ? I was running 8 psi in my tires and could not get better then a 1.7 60 ft , I went lower and manage to get consistent 1.6 60 ft times , best so far has been a 1.60 and alot of 1.62 ft times. Good luck and awesome #'s ! https://honda-tech.com/forums/images/smilies/emthup.gif
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krystianitr »</TD></TR><TR><TD CLASS="quote">CRXEE8
I think better if you put tranny from Integra typeR JDM and gear set ATS 1,3,4,5 https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE> $$$$ https://honda-tech.com/forums/images...s/emsmilep.gif I think my gearing i pretty damn good with the 4.73 FD. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8secEg »</TD></TR><TR><TD CLASS="quote">Lower the tire pressure more. What gear are you doing your burnouts in ? I was running 8 psi in my tires and could not get better then a 1.7 60 ft , I went lower and manage to get consistent 1.6 60 ft times , best so far has been a 1.60 and alot of 1.62 ft times. Good luck and awesome #'s ! </TD></TR></TABLE> Thanks for the advice. To bad this was the last event in Denmark. I did not try to lower the tire pressure from 8 psi but I will do that next year. I only did 1. gear burnouts because I was affraid that the traction bite would kill my axles when I got out of the water area with a 2. gear burnout. I know a 2. gear burnout could help me out to get more heat in the slicks but it will have to wait for the next event. |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastasscrx »</TD></TR><TR><TD CLASS="quote">I got a b16a in my crx and it runs high 11's in the 1/4! What type slicks you running?</TD></TR></TABLE>
*cough* bullshit *cough* |
what kind do you have gears in yours tranny???
Your tranny gears are fine. What kinda od throttlebody and chip in your ecu do you have?
