all in 1992 cx hatch
stock gsr 14.0@100 stock ls-t on drag radials 11.87@118 ls-vtec forged pistons/rods stock block on bfgs 11.53@126.xx |
ek hatch- 14.3@96
b16b jdm itr header aem intake 2 1/4'' piping 92 civic si hatch-15.4@88 stock d16z6 dc 4-1 header ebay intake everything else stock |
Re: (cisurfer1)
Full weight 92 DA b20vtec gsr trans
14.1 @ 99.6 mph 2.2 60s with Azenis now on 75 shot but no times yet |
Re: (FaStTeg)
94 si hatch
uberdata t3/t4 20psi stock sleeves 11.60@127 This year , aem ems t3/t67 psi????to be announced benson sleeves et. we will see https://honda-tech.com/forums/images/smilies/emwink.gif |
Re: 1/4 mile track times (youngtilidie)
ZC SOHC NON VTEC ALL MOTOR stock short block, on a eg hatch, sotck body, i just removed all of the interiors.13.54sec @100mph, 1.8 60ft, tires 22x9x13 M&H drag slicks bogart Pro 4 rims in the front stock rims on the rear.
engine mods Headworks by Port Magic Cam by FORCEDSPEED stage 2 278duration 12mm lift ECU- MICROTECH Forcedspeed adjustable cam gear Forcedspeed power pulley Showtime drag lounch kit 270cc RC injectors |
Re: 1/4 mile track times (forcedspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by forcedspeed »</TD></TR><TR><TD CLASS="quote"> ZC SOHC NON VTEC ALL MOTOR stock short block, on a eg hatch, sotck body, i just removed all of the interiors.13.54sec @100mph, 1.8 60ft, tires 22x9x13 M&H drag slicks bogart Pro 4 rims in the front stock rims on the rear.
engine mods Headworks by Port Magic Cam by FORCEDSPEED stage 2 278duration 12mm lift ECU- MICROTECH Forcedspeed adjustable cam gear Forcedspeed power pulley Showtime drag lounch kit 270cc RC injectors</TD></TR></TABLE> nice https://honda-tech.com/forums/images/smilies/emthup.gif elevation? sea level? im thinkin of buildin my head a bit like urs. what kind of money did u spend on a setup like this? let me know. pm plz.. https://honda-tech.com/forums/images/smilies/emthup.gif |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA9toED6 »</TD></TR><TR><TD CLASS="quote">man i dont mean to hate, but thats slow.
i had a 92 LS with a B18B, i/h/ and one junkass exhaust, and it ran a 15.3 and weighed 2500 lbs without me in it. somethings not right. maybe just practivce your launches?</TD></TR></TABLE> here is his problem: <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youngtilidie »</TD></TR><TR><TD CLASS="quote">1991 crx hf <U>0bd0 b18a1</U> aem short ram ebay header/rsr axle back 2.5 crush bent exhaust 2.5 catalytic conv. usdm ys1 tranny track in NJ (sea level) on 205/50/15 Kumho street tires 15.18 @ 91 mph </TD></TR></TABLE> my friends car ran 14.99 on his best pass w/ that engine in a HF CRX. He swapped to a 98' B18b and ran a new best of 14.2 @ 95. A year or so later he ran a 13.0 @ 102 on slicks w/ a stock GSR w/ i/h no exhaust. (ITR lsd tranny) |
Re: 1/4 mile track times (JDMs1eeper)
90 civic dx hatch(2156lbs full trim with out me in it0
ls/vtec p30 pistons spoon cams itr head itr manifold itr 4-1 header untuned m&h slicks on bogarts s1 trans 13.5@101 with 1.7 60ft 7500 rpm launches |
Re: 1/4 mile track times (AllMotr)
Here is a setup closer to yours.lol
92 b18a stock b16 airbox jdm dc sports header +2.25 exhaust 92gsr ys1 tranny 8.8# flywheel full interior and air 14.7-14.8's all day 2.20 60's |
Re: 1/4 mile track times (4potnick)
93 Civic Hatch CX:
93 DX motor 94 EX tranny, I/H/E, ACT clutch, chipped p06, street tires 15.5@89 mph (2.3 60ft) other 92 Civic hatch CX: JDM B20 with GSR tranny i/h/e, Skunk2 intake manifold, Crane stage 1 cams, 6 puck clutch, street tires, stock height, full interior. 14.4@94 mph (2.1 60 ft. w/ massive wheel hop)Can't wait for better mounts and lowering springs |
bump
Re: (cisurfer1)
full interior 92 si hatch
h22 with forged rods/pistons t3/to4e at 8psi ~260whp stock head 2.5" downpipe/exhaust hondata s200 ACT stage 2 clutch bald as hell parada spec-2's no lsd 13.5 @ 110 2.1 60' not too shabby for the first time ever going to the track with a manual car (I think) |
Re: (yeehonda)
1991 CRX Si
B16a (no LSD) Stock with Invidia Exhaust Full Interior minus spare and cargo cover BFG Drag Radials 14.53 @ 95.0 MPH 2.23 60' |
1990 civic si hatch
stock d16z6 w/tdoh5 @14 psi w/obd1 and uberdata shitty auto-x tires 14.1@102 2.6 60ft |
15.0 street tires 88 crx hf
Mini-me swap crower cam,valvesprings, and retainers zc pistons si trans zc ecu. needed to tune. R.I.P....bent valve https://honda-tech.com/forums/images/smilies/emsad.gif New project usdm type r turbo in 95 hatch, first run hopefully this week,keep ya posted |
Re: 1/4 mile track times (1QuikSOHC)
Sir iam from the philippines, iam the one who ported the clyinder head. https://honda-tech.com/forums/images/smilies/emwink.gif
Re: 1/4 mile track times (deadon)
ran today,
13.3 @105 mph 60 foot 2.050 https://honda-tech.com/forums/images/smilies/emsad.gif Weak but my slave was going out. Could'nt lock up in second gear, took awhile. I was'nt in vtec range after second. Then my slave went out, drove my car back home about 60 miles away with no clutch pedal. http://images.honda-tech.com/set1//smile/emcrook.gif |
95 civic lx 4dr
b18b 8lbs boost 14.158 @ 99 mph 2.4 60' hoosier street slicks i didn't pilot the car had to work. full slicks and suspension on order. |
first car
90 civic si, i-h-e, gsr throttle body, stock steelies with kumho tires, full interior tokico blues, eibac springs, 60ft: 2.284 sec 1/4: 15.5 @89 mph same setup as above but with vtec head, test pipe tuned on chrome 60ft: 2.172 1/4: 15.015 @95 mph New car 00 civic Si i-e-test pipe, b&m short shifter, act street disk and presure plate, fidanza lightweight flywheel, st front sway bar, 60ft: 2.367 1/4: 15.303 @93hp |
Re: 1/4 mile track times (Slow_import)
yo guys no one has a ef hatch with a jdm gsr motor?if someone does please posts some 1/4 mile e.t's
Re: 1/4 mile track times (HondaCivicSiR1)
Re: 1/4 mile track times (crxh22a4)
i just ran today it was my first time taking this car to the track...its a 90 crx si with a stock b16a no bolt ons it ran a 14.79 on street tires
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCivicSiR1 »</TD></TR><TR><TD CLASS="quote">yo guys no one has a ef hatch with a jdm gsr motor?if someone does please posts some 1/4 mile e.t's </TD></TR></TABLE>usdm 92 gsr b17...nothing like a jdm gsr but......14.0, 2.20 60's on crappy street tires
lsvtec 13.006 at 103mph 1.8 60FT time https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif
