Detailing Auto Detailing and Concours
taking off double sticky tape from Factory lip kit on my em2??
Old 02-18-2011, 11:49 PM
1320king's Avatar
Default taking off double sticky tape from Factory lip kit on my em2??
hey i just got my 04 civic ex coupe and it came with the factory honda lip kit, i guess it was optional when buy the car new, i dont like it so took it off now theres double sticky tape stuck on the bumpers and sides i dont know what i should use to get rid of the double sticky tape??
Old 02-20-2011, 03:37 PM
ddh052286's Avatar
Default Re: taking off double sticky tape from Factory lip kit on my em2??
3M Adhesive remover ($10 at autozone i know) and a razor blade or...
Windex and a razor blade.
Take the razor blade and hold it at an angle and squirt whatever you use on the glue or whatever.
Put the razor to the bumper and lightly scrub in a back and forth direction. DO NOT FORCE THE BLADE TO DO ANYTHING. Just lightly work the blade. Change areas of the tape if need be as some directions will make it come of easier. Have fun.
Old 02-21-2011, 09:50 AM
milkmanLCA's Avatar
heat gun and rub with finger till all that is left is adhesive. then use adhesive remover on a rag and rub away. follow with soap and water to get the adhesive remover off. do not use a blade, you will damage your car
Old 03-08-2011, 10:30 AM
Sanji
toyomatt84's Avatar
I would try Goo Gone, and let it soak.
Old 03-14-2011, 10:26 PM
MiG-21 superfan
builthatch's Avatar
this is probably what i would do - heat gun or hair dryer and fishing line or dental floss to lift off as much as possible. don't heat the paint up too much, just get it hot enough to soften the adhesives. and then use prep sol on a clean short nap towel or paper towel to remove the remainder, then clean, polish, clean and protect.
goo gone and wd-40 would probably work as well but i'm sketchy about using such oil rich solvents on the latest clear coats.
Old 04-14-2011, 07:10 PM
(. )( .)'s Avatar
try a cleaning product called "awesome" its in a clear spray bottle with yellow liquid inside. it will do the trick.
or wd40
Old 04-16-2011, 09:18 PM
alphalanos's Avatar
or wd40
be careful with this stuff it can damage finishes
Old 04-29-2011, 01:23 PM
(. )( .)'s Avatar
yeah true, but the bottle has instructions on how to dilute it. 50/50 works find for most finishes, its better to mix it a little stronger than recommended, i found the recommended mixtures to be a little weak. 100% pure works great on engine blocks.
Old 04-30-2011, 02:30 PM
redsi4's Avatar
Use Goo gone and a heat gun/blow dryer if needed.
hondapower321
09-28-2007 03:00 PM
truevietluv636
Paint and Body
08-09-2007 05:04 PM
EJ1 wilcox
70
04-12-2006 10:18 PM
digital sol
Welding / Fabrication
03-16-2005 08:01 PM
sweetwhitecl
03-05-2003 05:17 PM
Quick Reply: taking off double sticky tape from Factory lip kit on my em2??
