Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Detailing (https://honda-tech.com/forums/detailing-130/)
-   -   scratched windshield (https://honda-tech.com/forums/detailing-130/scratched-windshield-2896134/)
OBSESSED Feb 9, 2011 06:57 PM
while attempting to rid myself of watermarks on my windows i have aquired small swirl scratches from the product i used. what can i do to fix this at a reasonable cost? wax?
shwanC Feb 9, 2011 08:07 PM
Re: scratched windshield
What 'product' did you use? You may have etched the glass. Wax would probably not help. On a side note, I have used automotive paint cleaner (part of a waxing/polishing kit) from Meguiars and did a fairly good job.
92teginsc Feb 9, 2011 08:11 PM
i had the same problem and i could not get them out. so i just cracked the front glass on purpose and got a free replacement. lol.
builthatch Feb 10, 2011 06:05 PM
it's pretty hard (read almost impossible) to scratch glass with products meant for paint. what did you use?!
you can usually level scratches with a cerium oxide slurry and glass leveling pads. the key points are to avoid getting the glass hot and to not polish too much in any one area.
TheMuffinMan Feb 13, 2011 02:12 PM
Hmm, I've got a similar problem. I think during a tint removal the installer's razor blade light scraped the glass causing a shallow scratch barely visible. However when you apply tint on top of it it magnifies the scratch like crazy.
I'm wondering if some polish or something would take care of it?
builthatch Feb 13, 2011 02:36 PM
oh yeah, tinter razors can definitely do it, either too sharp or too dull. i had it happen to a passenger window in my brand new tacoma. i was LIVID. the guy never owned up to it which was ridiculous. i ended up getting new OE glass because the deep, long scratch was perfectly in line with the rear view window.
it really depends on how deep it is. it's very possible to level a very shallow scratch, but the deeper it gets, the higher the risk for developing a wave or distortion in the glass.
TheMuffinMan Feb 13, 2011 04:01 PM
Gotca, it's very very difficult to see if you're just looking at the glass from the outside, however running your fingernail up and down the glass you will catch it just a touch. I've considered getting replacement glass but I'm lazy :P and figured I might be able to polish it out. It's only about 3 inches long anyways.
Any suggestions though built? Will the cerium oxide paste help? I've seen some stuff that can "temporarily" reduce the appearance of them, it was like a mix of iron oxide and some other compounds. I'm not sure though if I could tint over that and have it look normal.
builthatch Feb 13, 2011 05:08 PM
it's on the inside or outside? i'm figuring the outside since tint is cut on the outside.
hard to say for sure. i believe it to hinge mostly on how deep it really is. the only evidence i've seen of scratches being removed is with a buffer and that cerium oxide. i've never done it - the most i've done is removed minimal to severe water spots from glass on many vehicles.
here is a dude who used it with great results -
http://www.autogeekonline.net/forum/...h-remover.html
apparently the process is very messy.
like i said the fear is making the glass distorted and/or if the scratch is even able to be removed. but if you have a buffer, it might not hurt to try.
autogeek sells some diamondite kits meant for scratches.
David Fermani, who is a well-respected detailer in florida, mentioned at one point he had a friend who would travel the country removing scratches on classic/exotic car glass. so, apparently there are pros out there who specialize in this.
TheMuffinMan Feb 13, 2011 05:43 PM
Appreciate it built, found this linked in the thread
http://www.autogeek.net/glass-repair-kit.html
Think this might work for me and looks relatively straight forward. It's actually a scratch on the inside of the glass, I had some tint removed for awhile and probably should have just done it myself.
ddh052286 Feb 20, 2011 03:44 PM
are you sure your glass is "scratched"?
Read this...
http://www.ehow.com/about_5642104_ca...ch-glass_.html
