Detailing Auto Detailing and Concours
Should I pressure wash the underside of my Civic?
Old 10-26-2017, 04:59 PM
Vtec04's Avatar
Default Should I pressure wash the underside of my Civic?
My Civic used to leak oil from every single seal on the engine, which covered the whole underside of the car in thick grease, which collected lots of dirt and sand. It bugs me a little, but I haven't had time to clean it yet. I kind of wonder if I even should clean it since the oil may help to prevent rust lol. But realistically the filthy grease all over everything probably accelerates rust by trapping moisture. Should I clean it? What do you think? Thanks.
Vtec04 is offline
Old 10-26-2017, 06:17 PM
Sanji
toyomatt84's Avatar
Default Re: Should I pressure wash the underside of my Civic?
Oil and water don't mix. So, if anything, its repelling any moisture, not "trapping" it.
toyomatt84 is offline
Old 10-26-2017, 06:18 PM
Vtec04's Avatar
So I would make rust more likely by washing the oil and dirt off?
Vtec04 is offline
Old 10-26-2017, 09:48 PM
Sanji
toyomatt84's Avatar
Only if there's exposed ferrous metal. If its coated (like a painted underbody or oil pan), then no it won't rust anymore then when its covered in oil. Unless you see a ton of road salt and are negligent with your car's cleanliness, you won't experience any abnormal rust issues.
MikeD21
Transmission & Drivetrain
01-01-2019 09:11 AM
94civicex.
09-16-2010 01:59 AM
Root of all Evil
22
03-13-2008 02:09 PM
Oregon
25
10-18-2006 10:51 AM
serious
03-23-2004 10:03 AM
Quick Reply: Should I pressure wash the underside of my Civic?
